Hey guys, Here's the story. S13, CA18, T25G, 14psi, Iridium spark plugs gapped to .7
If I drive along in second at about 2800rpm and drop the throttle flat (or if I happen to drop back from 3rd to 2nd and flatten the throttle, the car will mis and splutter from around 2800-3000 rpm up til as late as 32-3400 rpm.
This is much more prevalent when the car is fully up to temp.
I've tried swapping in different coil packs, cleaning the electrodes on the coil packs (no cracks on the existing or addition tested coil packs. Putting fuel into the map there (SAFC) taking fuel out of the map there. Swapped over the coil pack loom.
Plugs are a heat range 6 so a range colder than factory and are only 3000-3500 ks old, about 1000-1500 of those would be track ks. The plug shows white discolouration that correlates to the high rpm usage (this is a track car).
What are your thoughts? I'm thinking of grabbing a cheap set of plugs today to test, but the iridiums were $25 each and are only 3500ks old, the car only makes 165rwkw.
Initially I thought coilpacks or tuning but after trying two sets of coils and putting all the fuel in and taking all the fuel out it doesn't seem to help.
https://www.sau.com.au/forums/topic/371808-misfire-coming-on-boost/
  • Replies 51
Something probably really anoying like; a vacuum leak or a seal somewhere.
Try letting the car idle and listen for air hissing or maybe even trysoap to watch for any bubbles. Also try this maybe with a friend leave it nuetral and rev to build-up pressure.
If not this maybe an oil pick-up issue????
Do you have an aftermarket CPU, get it dynoed...
Good Luck
Im thinking that if it was an air leak then the problem is it's too rich and I took all the fuel out of the map to test and it made no difference.
Car has been on the dyno an has a tuned ecu, I have the safc to monitor and make small ajustments
New plugs gapped to .65 and fresh fuel, still doing it. The fuel filter is only 1000ks old as I considered that.
I'm going to do a bit more testing with the tune as it "feels" like mix related, though I did consider timing?
try 0.5mm gap, if we are required to use them we run all our iridium and plats @ .05mm without power loss.
This.
Had one of these motors at 20+ psi with a disco and could only ever do it at 0.6mm or smaller.
SR eater.
Sorry missed your prior reply.
As a test try crimp your fuel return hose after the FPR. If it works then its your FPR.
Ok re-gapped plugs to .5 noticed that the new plugs are already quite black with carbon , not fuel or oil, a dry build up. Interesting given they are only 50ks old.
Will test drive when the road is dry again, too hard to test in the wet.
Ok weather is finally good enough to go test at .5 will do after work.
Anyone care to explain how crimping the fuel reg hose will help me test?
Whether the FPR is busted and not holding pressure up to your injectors. Crimping will increase fuel pressure to the rail if there isn't enough now.
Ok felt guilty so went for a drive and skipped the last bit of top gear!
A few things to note. Gaps were .5 and I also noticed a plug on top of the air regulator under the throttle body had come off so I fixed that.
Went for a drive and it was only right at the end of the drive that it started to miss a small amount and bog down if I flattened it from 25-2800 onwards. I think it was too cold last night as normally when it does it the water temp has come up to 70 and it only got to 60 last night as it was late and quite cold. Water temp sender is in the rad return hose FYI.
I noticed too that when the car is warmed right up and starts missing it also appears to rev up slower. Wondering if this could be a electrical issue with the cas. I'll take a look at the service manual for the testing procedure and will test the crimped fuel reg next as I only wanted to test one thing at a time.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
