Hi gangs, just wanted to know which shop in the west can set up my coilover with a decent price. Been ringing around and the cheapest i got is $370 labour + 4 wd alignments. Is there any other better place/price?? And do i need to specify the set up? I dnt know much bout coilovers. Its a daily drive so i guess set it up for soft ride? Btw its bc br coilovers..
https://www.sau.com.au/forums/topic/372986-coilover-set-up/
Why don't you just adjust it yourself? Doesn't it have a knob on top of each coil that allows you to turn up and down your ride stiffness?
It just takes a few trial and error to get it to what you like?
https://www.sau.com.au/forums/topic/372986-coilover-set-up/#findComment-5949276
Do you have a Jack, a socket set, basic screw drivers, and a torque wrench? If so you can do it yourself quite easily do it yourself (not the alignment part obviously) but you should be able to change them if your good with your hands. If you don't have all these things you can easily buy them for less then what labor charges will be at any workshop
https://www.sau.com.au/forums/topic/372986-coilover-set-up/#findComment-5949417
Well, im afraid to say my hands are not good with these kind of job. Hence ive been ringing around for shops to do it for me..Id be more happy to give my money to someone from here who would do the job right.. Any volunteers? Cash for grab!! Lolz
https://www.sau.com.au/forums/topic/372986-coilover-set-up/#findComment-5949550
traction tyres down in rowville set my bc coilovers up
was around the 300 dollar mark for the labour, they didnt just wack them in and left it they set it up 100% and when i picked it up they walked me through it on how they set it up.
there would have been another charge for the wheel alignment, but mine was still ok so they just checked the alignment and didnt charge me for it.
https://www.sau.com.au/forums/topic/372986-coilover-set-up/#findComment-5952810
$300-$400 is what i would expect to be paying for coilover swap out.
And then another ontop for the alignment and stuff which will take a while.
I also use Traction Tyres. Won't use anyone else after 4 bad experiences @ other places over the years.
Not really helpful given you are out west, but all my bad experiences were from the west/north unfortunately :(
I'll also take a stab you'll end up having to replace other worn parts in the front end. So expect the bill to go up a little more. Perhaps wheel bearings, tie rod ends etc. Those things get old and if not changed before they will no doubt be stuffed or close too it.
https://www.sau.com.au/forums/topic/372986-coilover-set-up/#findComment-5952822
Centreline
72 Lipton Drive
Thomastown 3073
These guys are awesome. They may seem a little blunt and plain at first, but they're willing to teach, do a great job and Glenn gets real excited when you chat about KA and KB Lasers.
Thomastown shouldn't be TOO far from west side.
https://www.sau.com.au/forums/topic/372986-coilover-set-up/#findComment-5954751
You may as well get it all done at the same place, don't see much point getting install done a place a) and then alignment done at place b) -
make the drive to Traction Tyres, definitely worth it.
Do you have sway-bars?
https://www.sau.com.au/forums/topic/372986-coilover-set-up/#findComment-5956385
How come you asked abou sway bars?...
Does it make the installation harder?
Coz I got some Teins in my car and I need to install a pair of Nismo sway bars...
https://www.sau.com.au/forums/topic/372986-coilover-set-up/#findComment-5957664
If you want someone to do it for you and also the alignment I definitely recommend traction tyres, I went to them after being recommended from the guys here and I am very happy with there work they did on my alignment on all my arms.
https://www.sau.com.au/forums/topic/372986-coilover-set-up/#findComment-5957929
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
