In OZ I suggest a larger trans cooler fullstop.... Summer time is a killer on most elements of this car....moreso on the gearbox and plenum temps.
No harm in putting in some kind of thermostat either for winter.
  • Replies 183
Might get one of the B & M ones then, check out Jase's on the cruise and see what I think.
Keen on getting the IC sorted first so I can work out how much room there is :S
TONS!
Best thing I did was relocate the horns to the side, gives you a shedload of room to work with. I should really stop being so lazy and just take a decent photo. If I get time, I will tonight!
Jetwreck installed my shift kit yesterday arvo, while I got in the way and generally hid Allen keys for him...
When you open the box and see just what you get for your money, you'd be entitled to feel a little short-changed.
However, patience is a virtue, and it will be rewarded with a gearbox that simply provides the absolute best of all worlds! At light throttle openings; beautiful smooth but fast shifts, not harsh at all. At higher throttle openings (around 3-4000rpm) firm fast shifts with a nice squat from the rear as it picks the next gear.
At full throttle, shifting at Redline on damp roads, mine now squats down, shoves you into the seat and spins the rear wheels for a car length until the torque split throws power back to the front!
Yeaaah! That's what it should be like! This mod has just scraped off the veneer of respectability that the NM35 has, and I can now see the potential it must have with another 30% to 100% more power.
If you are tossing up whether to do this mod; DO IT! YOU WILL NOT REGRET IT!
If you are tossing up whether to do it yourself; have a good hard think, and honestly assess you mechanical ability. If you are not extremely confident in your ability; leave it for someone who is.
There are many small procedures that must be done correctly TO THE LETTER, if you get just one wrong; you could well be f##ked. If you lose one tiny detent ball, or lose a spring; you're going nowhere.
I watched Craig go through the entire process, and assisted at key points, and this is not a simple job. To be entirely confident, I'd be wanting to go through the whole thing again, with his assistance.
I estimate it would take me between 6-8 hours to do my first one; checking everything twice. It takes Craig around 4 hours.
I also used Nissan Matic-J at $69 for 5lt, rather than Nulon at $59 for 4lt. You need around 8lt, so you'll have enough left to do a transfer case flush as well.
Thanks again Craig for your efforts yesterday, I couldn't be happier, the car is f##king awesome!
Edited by Daleo
Nice Dale!
veneer of respectability - I like that!
Mine will be going in tomorrow - we'll see what changes they made in the GB with the TCU and things. I really don't need the shift kit at the moment- I find the behaviour of my gearbox to be fine. What I am pre-empting is that things will be radically different when it gets some boost in it over the next couple of months, and being on the dyno for a day I don't want the gearbox to expire.
I'd be interested to see what's the diff between the transgo kit and the kit I got. If its a huge difference I might shell out for one...$260 is farking cheap...
I can't remember what the stock transmission was like...all I know is that I never used the tiptronic mode before I had my shift kit installed...and now I use it all the time :whistling:
Just come back from my install with Jetwreck.
Can only echo everything that Dale has said above. At parts of the process my mind was boggling! There were differences in my gearbox- namely we had to lower the crossmember to allow access to a plug on the drivers side- that connects to the Transmission ECU, which is sitting in the gearbox. Difficult with the exhaust in the way.
Shifts are still sliky smooth for me on low throttle, while the gear box performs much more positively on upshifts at WOT. It doesn't have quite the same effect as Dales, but then again, I'm lacking boost! Once that changes, I'm sure it will come into its own!
All sealed up again after a bent pan rail sprung a leak.
Bit of a touch up with a hammer; all sorted. Also knocked over the transfer case fluid change.
Thanks again for the use of the hoist Craig; heaps easier than battling on the garage floor.
Beers are on me next time.
Fark this shift kit kicks arse!
Edited by Daleo
looking forward to a weeks break on this now as the next 4 kits wont be hear for a week.....I recounted....thats 7 NM35's and 1 PM35 I have done.......4 since Wednesday.
On other news guy's if you want kits I am after another 2 to add to the next buy.....to keep shipping costs down.
Well done mate; man on a mission!:thumbsup:
Get on this guys; this is my new favourite mod.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
