  • Replies 41
  • 9 months later...
WOW been a while since i updated this thread, sorry guys thought i was upto date here. Time to catch up.
When she came into Canada
photo13.jpg [/img]
Engine is sound, electrical could do with some work tho as expected.
Cleaning out the car and realized it needed new carpets and some trim repair. So i thought F it, just strip the damn thing and build it right the first time instead of doing things gradually. So i started to gut her last night.
Funny what you find in a car this age, plus I'm glad i did it. found that the seats were missing bolts to hold them down.
hmmmm interesting rear seat belts, bolted from both ends with no buckles, looks like left overs from race harnesses. The seats are recoaros with bride rails and there was some bride stickers inside the car. If this car could talk!!!
I'm gonna continue stripping it down till its just the drivers seat and steering wheel left.
gonna get new carpets and re do the interior trim in suede
Picked up rear Skyline R32 seats and they fit!!! little bit of modding to look perfect but brings up the interior to the modern age a little.
Trying to figure out a way to make the ride a lot smoother than it is and found out a few guys had done S13 Coilover conversions. There was not a lot of info out there on the swap but it was possible with some custom work done to the control arms etc.
almost stripped
on the way to the shop
I ordered a set of Apexi S1 coilovers and bought a set of s13 spindles, hubs and cailpers to upgrade the handling and change the rears from drums to discs.
Pulled the old shocks and springs out and OMG. only 2.5 coils from the cut springs f-ing ridiculous lol
Taking out the rust from under neath
Picked up some s13 spindles and calipers gonna try and make them fit the front. Before
After
I was blown away at how new these look after the refurb.
Test fitment on the new
Front coilovers will take a bit of work installing. We have to extend the control arms of the s13 and will have to figure out something with the steering rod too.
Rears is a straight fit just need to make an adapter for the top becuase the skyline is a 3 bolt at the rear and 13 coilovers are a 2 bolt.
Rust Removal has already been done on inside and coated. Bee Quite sound deadening material is being used for all the interior.
Dash is going to get sent to ASC to get wrapped with leather. bubble and cracks need to be taken care of.
Going to paint the interior myself. Gonna change it from gray to black, using SEM products apparently the best stuff to use in the bizz. Some of the paints are like $50 a bottle!!!!!!
Update on the body work. Trunk lip was remade in bondo in certain spots where the rust had eaten it away.
got to work and cut away existing rust and made new sheet metal where necessary.
Trunk before hand surface rust everywhere
Got rid of the rust and coated
Interior before
Interior after
Wheel arches coated in the same coating too
To fit the coil overs to the rear we'll have to make adapters. Brinkworth fabbing some up.
Old rear set out.
New ones in and Drums refreshed. Looking pimp!!!
Like i mentioned before the fronts are way more complicated to fit. we had basically two options, butcher the front coilovers and weld them in. Didn't really feel like potentially ruining brand new $2000 coilovers lol so we went with option 2. Getting s13 control arms and spindles and modding them to fit.
We had to extend the s13 control arms and make them a bit of conbination of c210 and s13 control arms to make them fit.
Painted up and ready to go in
Had to fab some bushings as we couldn't find c210 bushings. found out that 80's VW Golf bushing fit with a little bit of tapering.
Fronts all in and looking good,
He even found Chevy cavalier sway bar bushings that will be a good replacement for the skyline ones
Edited by Sukh
bolt pattern conversion caps for the rear coilovers machined up and looking sweet!!!
Custom made braided brake lines
Rear end pretty much complete, now just need to slip in the coilover and all done!
Only thing left for the front is the steering linkages need to be extended then the front is done!
Shortened some universal sway bar bushing and they are a perfect fit
Wheel well had some serious rust before now it looks like new!!
Some shots of the interior now its 90% complete
Door panels
Rear seats
Quick photo shoot we did with a buddy of mine
Took it out to its first meet and won my first Trophy/clock lol for best Nissan
Next is install the sound system. Planning on putting 4 - 4inch speakers inside, 10" sub in the back running off one amp. At the same time do a battery relocation to the trunk.
Anyone done a battery relocation and wire tuck on a C210?
dude firstly, absolutely amazing job!!! im dead-set blown away.
secondly, is there any chance you could post up a recipe for the front s13 coilover conversion? i would kill to get my conversion looking that neat. ive gone a totally different route but yours looks WAY better.
the only plus side to the set-up im doing is that it will be fully adjustable. but yours is just so clean and stock looking.
the million dollar question is, how does it handle? would like to know about the driving experience now that you've done the swap.
man my jaw is still droppped to the floor.
just 2 more questions mate. can you tell me what you used for front brake lines?
and how much were those LCAs to get made?
much appreciated :-)
cam
  • 10 months later...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
