As the title states it's ideling @2000rmp then intermittently drops to 1400rpm for a split second then back to 2000rpm.( is like the computer is cutting ignition to try control it)
Things i have done
replaced all vaccume lines
All inlet gaskets
All spark plugs
Replaced coils
Changed injectors
Changed idel control
Done nissan consult no errors shown
Pluged exhaust and turbos and pressure tested it with 25 psi no leaks anywhere
Drive fine when above 2500rpm or on boost
Anyone had a simmilar problem, any ideas?
Will post a link later of a video of what it does
sound like injector cut is coming in....the ecu sees via throttle sensor that the throttle is closed and its seeing the rpm exceeding what it deems to be a normal idle speed so it pulls the power to the injectors.....you have a vac leak or BAC valve is letting too much air past
If you unplug the idle control valve electric plug does the idle return to normal, this is what my car is doing, 1500 rpm idle just started doing it one day, I unplugged the electrical plug and it idles as normal. I still need to look into this drama
Have you checked that the TPS is giving a "throttle closed" signal to the ECU. This will be indicated by the ohms between pins 1&2 (I think, could be 2&3) is 0, and "not 0" when throttle cracked open.
Is the brake booster leaking? Remove all the larger hoses from the equation and plug them, it sounds like a decent leak anyway, cant be too hard to find...
there are no leaks as stated in the op ( did a pressure test with the engine not running and put 25psi in it, NO LEAKS)
If one of the throttles were open more than the others could it make it do this?
I agree with what you're saying about the injector cut, there is no vac leaks anymore as they have been sorted and tested with 25psi, is bac valve the same as the idle control under the plenum? or is it something different?
idle don't change if u unplug it, that was one of the first things i tried!
thanks anyway
Incorrectly adjusted throttle plates can cause this. The reason the engine is revving and cutting back is called Overrun. The ECU sees closed throttle and over 1300-1400rpm so it thinks it's in decel. It cuts injection as it normally would on decel. Then the idle drops far enough that it comes past it's overrun threshhold and goes back to high idle, once again, repeating itself.
You can try backing off the single throttle stop adjuster on the main throttle link above the plenum. Make small adjustments as this should never really need to be touched. Another way to check it is to undo the 4 mounting bolts on the T bar and force the plates shut by hand. If the idle drops then you need to adjust the main throttle stop. If it's just one throttle plate that needs adjusting, they have an adjusting screw and 8mm locking nut beside the throttle plate on each pair. Be careful and only do this if you know what you are doing.
There may be no air leaks but air is certainly leaking. All it has to do is get past the throttle plates somehow
i was thinking that air is leaking past the throttle on cyl 1 & 2, will check the idle control one more time & then if its still no better i'll adjust the stop on the throttle plate itself. will let u know if i stff it up :)
OK, I READ THE OP JUST FINE MATE...
Do you know there is a one way valve in the booster line that wont let boost past, but will allow air to flow back to the engine? If the booster is split it would cause you issue, I thought it was weird it wasn't leaking with pressure but you obviously have a big vac leak.
What about the PCV?
Good luck with it anyway.
What about the PCV?
I have disconnected the boosters and blocked them off, same goes for the pcv.
Unfortunately made no difference
Thanks for the input everyone
PROBLEM FIXED!!!!
Big thanx to Dan from Elite Racing for supplying a set of R34 Throttles today,
fitted them up this arvo & it runs Beautifully just need to set the idle a lil lower as it is around 1100rpm but is alot better than 2000rpm, drives alot smoother, no miss or hunt
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
