Is it only in 1st? K&N pods are oiled, and have had bad experiences of the oil on them getting on the afm hotwire, a spray with a bit of electrical contact cleaner helps that out. Other things are make sure it's not overboosting and hitting boost cut (could be a line disconnected/not plumbed right), or other things I'd check are change spark plugs, if they're new, could be coilpacks giving out under load.
https://www.sau.com.au/forums/topic/373518-stagea-choking/#findComment-5957967
I'm gonna throw boost cut into the mix, have you
Got a gauge fitted?
Mine has a similar issue, had it when it was stock and still does it mow, just not as bad, with every breathing mod I've done it has gotten better.
I'm running standard boost control, full 3" turbo back system with a blitz pod, and my car makes 0.9 bar of boost, ie 12-13 psi. Maybe yours is like mine and it is over boosting.
https://www.sau.com.au/forums/topic/373518-stagea-choking/#findComment-5958303
If its airflow cut you'll know when you hit it. It's a complete engine cut, feels like the throttle got slammed closed and the engine revs down. By the way S1's don't have a boost cut, no way for the ecu to know the boost pressure.
Has it always felt this way? Or just recently? The stock setups on all rb's is fairly restrictive especially the exhaust, and the stock mapping doesn't favor consistent pull through the rev range, they tend to flatten out around 4500rpm.
https://www.sau.com.au/forums/topic/373518-stagea-choking/#findComment-5958391
hey guys thanks for replying. its not sparks as i have new lithium ones. i dont hink its air flow coz my revs stay high all the way till it changes gear and keeps driving normal. its not just in fisrt gear. i first noticed it couple months after i got it which is when i put my k&n on. so maybe it is my afm?
sorry i said my car is stock but i didnt think about but i have a 3" all the way and a hi-flow cat. I got the cat put on coz i thought that was the problem. then i got my dump pipe changed and that didnt fix it either. it already came with massive exhaust when i bought it.
so its either the FM or coilpacks?
ive researched abit n thought maybe the ecu needs tuning. i dont know how it works. this is my second car but my first turbo. man the stagea is awwesome.
thanks for your help guys. please keep helping. some mechanics dont even know what a stagea is.
https://www.sau.com.au/forums/topic/373518-stagea-choking/#findComment-5960043
Overboosting is usually caused by a dodgy boost controller, or when you have the stock set up could be vacuum lines not set up correctly.
I'd say it's either your coilpacks or AFM though. Easiest/cheapest option would be try to give the AFM a good clean with contact cleaner first.
https://www.sau.com.au/forums/topic/373518-stagea-choking/#findComment-5960169
Somewhere there is a thread on checking the soldered joints insde the AFM connector. I did not do that as I had a spare.
If cleaning the sensor wire does not fix it, see if you can find the fix it thread.
https://www.sau.com.au/forums/topic/373518-stagea-choking/#findComment-5961246
Hey Guys thanks your support and help. Got my stagea from mechanics yesterday and it's running smooth. I didn't know they go so hard. Turns out the choking problem was related to my spark plugs. I didn't install them properly.I just put them in and didn't do the whole right measurement thing. Don't kno what it's called. Thanks guys. I'm happy with my car now. Also got a boost gauge so I can keep a eye on turbo. also had manifold replaced coz I had a tink crack.
https://www.sau.com.au/forums/topic/373518-stagea-choking/#findComment-5970844
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
