  • Replies 106
OK, final list of attendees, who else is coming along.
7.30pm this thursday, Orchid Thai at Abbotsford
4DoorGTR
Duncan
Kel
Franks
SW20-GT (whatever that means lol)
Merli
mmmgtir
Abo Bob
Carlo
Kinks
Akira
Maybes:
Endorean
Shonen
and Kabab bails at the last minute!
Big turn up, anyone else interested better let us know quick!
Still comming at this stage guys, but not in the GTI-R :rofl: Just dropped it off at the panel shop this morning. I'll be bringing an 80's Alfa GTV, am I still allowed to come? :Oops:
Richard
Hey at least the alfa has a track pedigree! (it's my friends race-car-in-progress). Plus, it's white with one red door, some cams and a set of extractors - it's a fanging machine!! You sure get plenty of stares in it.
Richard
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
