Alright cool, I was planning on doing it that way but wasn't sure if it'd be the correct reading as I tried to test the VCT with the hand controller but when I unplugged the plug for the VCT, hand controller still told me it was activating and deactivating haha
Would using a multimeter be a more accurate measure?
  • Replies 55
I'm pretty sure my car has been a manual all along though. Dash cluster is a manual one, the stock ECU that came out was a manual one and there was only one other owner of the car before me. Weird.
.....don't forget the half a dozen owners in japan before that guy too...
Ahhh I see. No dramas then, on my lunch break I'm gonna go sit in my car and start mashing the throttle without starting it haha
On one hand, I kinda hope the TPS is the problem as I'm starting to get over the fact my car barely makes more power than a midly-fettled GTS-t pinch.gif
Just a bit of an update.
Car overheated today as the rubber hose connecting the turbo water line to the block split and caused coolant to spray everywhere. Car had to get towed.
Which raises the question, if there was an issue with the cooling system, how much would this affect timing and if it does, what hardware will it affect to cause the timing issue (eg. the turbo becomes heatsoaked and in turn superheats the air)
Also worth noting the car has run hotter than normal since the timing issue surfaced, so not sure if timng issue and overheating issues are 2 isolated problems or are connected somehow.
Ideas and thoughts would be great :)
  • 5 months later...
Oh forgot to mention, knock usually occurs in the upper RPM range. At first we thought it was a VCT issue as that's when the knock starts becoming very unstable but we've ruled out the VCT by running it both plugged and unplugged.
Also worth mentioning that the fuel rail around cylinder 4,5 anıd 6 has gone from the factory greeny-metallic colour to a heated titanium sort or bluey-rainbow colour.
if the car is getting hot, and is underpowered, then there is a very good chance that your timing is retarded.
Your CAS might be stuffed.
I'd be checking the timing with a timing light, and then if you do adjust the cas, I wouldn't be driving it around hard until a retune is done.
Ok thie relates to my last post ... Tried to copy info and add using the phone ... Didnt work ...
Anyhow, just thought, if there was no change between having vct connecyed or not, could that not indicate that the vct is not working?
Also, excess fuel flow is iften used the keep the fuel rail cool. The fuel rail gettinh hot to tye point if discolouraton my indicated that you hage reduced flow out of the rail and hence cooling flow to the rear injectors or you have something making it hot. This would heat the fuel and change the fuel flow out of them. If up, the ecu would lean out the others if flow goes down, well theres your knock.
Just my thoughts.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
