I have one of those 30% more clamping purple clutches..
It has been pretty damn good and lasted almost 2 years of hard launching & gear changes. It has always slipped a little easier than expected however the front seal of my gearbox does seep a little oil so I assume this is the cause.
  • Replies 91
  • 1 month later...
I put an exedy Twin Plate (new) clutch with lightened flywheel in my 33GTR yesterday. My old Heavy Duty Exedy Single was stuffed!!! had nothing at all left on it when we got it out... value for money on that clutch :D
The new twin plate is great from what i have driven so far, no rattling (yet, will happen when it gets a bit worn i think)... bites hard, bit heavier under the foot, but still very drivable.. I'm happy with it, makes my car feel tougher...
Nismo use the same exedy twin i put in...
how can a twin plate clutch be easy to drive on the street as a daily driver?
Simplistically a single plate clutch, to hold say 500 bhp, has to have a much higher clamping pressure than a twin plate to hold the same 500 bhp. The reason is that there is twice as much surface (friction) area to transfer the torque in a twin plate. So if you have found other twin plates harder to drive then that would be because;
1. Maybe they are set up to handle much greater torque loadings than the single platers you are comparing them to
2. They are set up to suite a particular requirement, not what they are being used for ie; quick change, no slip competition
3. They do take some time to get used to, with twice the friction area they are quite different in feel
4. There are types of twin plates (solid centre, puck, ceramic, cermatallic etc) just like there are different types of single plates. Not one type suites all.
The reality is once you get to a certian power level you really have no choice, a multiplate clutch is a must. So the best you can do is choose the one that suites your own requirements and preferences. :D
good info here...
i need some input on this...i installed an orc twin plate
on my bro's s14...straight from the start when you clutch in
there is a real loud continues rattle...i didnt think much of this
and thought it was just caues its a multiplate clutch, am i right?
big problem is...it wont go into gear now.. after the install it was
fine, hard to get into first and reverse...then it loosened up after
about 500k's and now it wont go into gear... engine off no probs
but no luck when on..what could be causing this?
i've noticed that the 'rattling' when clutched in is not as noisy as
before too.. im thinking somehow the fork as shifted on the bearing
holder or something...
final question is when you guys installed your multiplate clutches
did you need to machine the bearing holder so that the bearing sits
further back from that of the factory position? to compensate for the
extra width of the new clutch?
any help would be GREATLY appreciated...
I'm going for a 3000lb 5 puck ceramic clutch in my GTR. A mate is running one and it seems to be up to the job so far in his GTR. it's a bit bitey but so was the one in my GTS-t so i'm use to it. cost me about $650, was going to install it myself but I'm kinda tight for time so I'll prob get it done at the mechanics along with getting the flywheel machined.
i just got the exedy single plate organic sports... driven about 400kms and bites quite good... but i still have trouble nudging forward and reversing as it shudders... not sure how long before this wears off.
I have the same and it does it, I'm not sure what causes it, but the simple and easy answer is not to ride the clutch.
Lunatic Dancer: Exedy Twin Plate....
no rattles/noises (yet, will probably get them when its worn a bit)
In fact, it actually fixed a noise which i thought was my gear box...
When in neutral, clutch out (engaged) it made a sound like something spinning, i thought it was just worn gears on my gearbox....when pushing the clutch in (disengage) it went away... after changing my clutch, that sound has totally gone....
Thinking of getting the Nismo coppermix kit from Nengun ~400ps $1600 delivered comes with pressure and clutch plates, thrust bearing and lightenened flywheel. OR
From Taka Kaira, Ogura Kit ~400ps also $1600 delivered with above parts.
Anyone heard any good stuff on these?
Duncan: Yes we changed my thrust bearing with a new one when we did it, the old one seemed fine tho (was a bit black from clutch dust, but spinning fine)....
As for the clutchs from overseas - be careful about 'delivered' prices... with a box that heavy and that big, you may get slammed with customs tax
Sydneykid...
Sydneykid...
Yep that's right, but not all multi plate clutches rattle. Some have anti rattle springs, they are silent just like a single plate.
Since there are 4 friction surfaces, they wear in a lot compared to a single plate with 2 friction surfaces. So they need adjusting, otherwise there is not enough movement to dissengage the clutch. Nissans don't have adjustable rods, they use a byspass in the slave cylinder to take up the slack caused by normal wear. Refer below.
Unlikely, it is usually all or nothing when it comes to fork movement.
No, but I have never done an S14 (or an S13 or an S15) for that matter. There are however a number of different Nissan fork pivots, some are longer than others. You need to choose the right one to position the clutch fork in the right place.
It sounds to me like you might have had the wrong fork pivot (too long) and that's why you had to machine the thrust holder. So how to fix it? Well, I would try a longer rod, that will at least eliminate the lack of travel question without removing the gearbox. You could weld a short piece of rod onto the standard rod or find a slightly longer Nissan rod from a different model. You used to be able to buy adjustable rods, do a bit of shopping around.
Hope that helps. :)
PS; it is not unusual for R32s' to break the pivot ball, I don't know whether this applies to S14's. You can easily check by looking in the fork hole with a torch.
SK,
Some multi plate clutches require a shortened thrust bearing carrier. ORC and HKS are the two brands i witnessed this with. Nissan make different length carriers as well.
I've never altered my pivot points as it creates more complications as you've mentioned.
Lunatic Dancer,
I think you may have mentioned out too much from the carrier which is ending up reducing your throw.
Did you try giving the system a good bleed...?
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
