I have one of those 30% more clamping purple clutches..
It has been pretty damn good and lasted almost 2 years of hard launching & gear changes. It has always slipped a little easier than expected however the front seal of my gearbox does seep a little oil so I assume this is the cause.
  • Replies 91
  • 1 month later...
I put an exedy Twin Plate (new) clutch with lightened flywheel in my 33GTR yesterday. My old Heavy Duty Exedy Single was stuffed!!! had nothing at all left on it when we got it out... value for money on that clutch :D
The new twin plate is great from what i have driven so far, no rattling (yet, will happen when it gets a bit worn i think)... bites hard, bit heavier under the foot, but still very drivable.. I'm happy with it, makes my car feel tougher...
Nismo use the same exedy twin i put in...
how can a twin plate clutch be easy to drive on the street as a daily driver?
Simplistically a single plate clutch, to hold say 500 bhp, has to have a much higher clamping pressure than a twin plate to hold the same 500 bhp. The reason is that there is twice as much surface (friction) area to transfer the torque in a twin plate. So if you have found other twin plates harder to drive then that would be because;
1. Maybe they are set up to handle much greater torque loadings than the single platers you are comparing them to
2. They are set up to suite a particular requirement, not what they are being used for ie; quick change, no slip competition
3. They do take some time to get used to, with twice the friction area they are quite different in feel
4. There are types of twin plates (solid centre, puck, ceramic, cermatallic etc) just like there are different types of single plates. Not one type suites all.
The reality is once you get to a certian power level you really have no choice, a multiplate clutch is a must. So the best you can do is choose the one that suites your own requirements and preferences. :D
good info here...
i need some input on this...i installed an orc twin plate
on my bro's s14...straight from the start when you clutch in
there is a real loud continues rattle...i didnt think much of this
and thought it was just caues its a multiplate clutch, am i right?
big problem is...it wont go into gear now.. after the install it was
fine, hard to get into first and reverse...then it loosened up after
about 500k's and now it wont go into gear... engine off no probs
but no luck when on..what could be causing this?
i've noticed that the 'rattling' when clutched in is not as noisy as
before too.. im thinking somehow the fork as shifted on the bearing
holder or something...
final question is when you guys installed your multiplate clutches
did you need to machine the bearing holder so that the bearing sits
further back from that of the factory position? to compensate for the
extra width of the new clutch?
any help would be GREATLY appreciated...
I'm going for a 3000lb 5 puck ceramic clutch in my GTR. A mate is running one and it seems to be up to the job so far in his GTR. it's a bit bitey but so was the one in my GTS-t so i'm use to it. cost me about $650, was going to install it myself but I'm kinda tight for time so I'll prob get it done at the mechanics along with getting the flywheel machined.
i just got the exedy single plate organic sports... driven about 400kms and bites quite good... but i still have trouble nudging forward and reversing as it shudders... not sure how long before this wears off.
I have the same and it does it, I'm not sure what causes it, but the simple and easy answer is not to ride the clutch.
Lunatic Dancer: Exedy Twin Plate....
no rattles/noises (yet, will probably get them when its worn a bit)
In fact, it actually fixed a noise which i thought was my gear box...
When in neutral, clutch out (engaged) it made a sound like something spinning, i thought it was just worn gears on my gearbox....when pushing the clutch in (disengage) it went away... after changing my clutch, that sound has totally gone....
Thinking of getting the Nismo coppermix kit from Nengun ~400ps $1600 delivered comes with pressure and clutch plates, thrust bearing and lightenened flywheel. OR
From Taka Kaira, Ogura Kit ~400ps also $1600 delivered with above parts.
Anyone heard any good stuff on these?
Duncan: Yes we changed my thrust bearing with a new one when we did it, the old one seemed fine tho (was a bit black from clutch dust, but spinning fine)....
As for the clutchs from overseas - be careful about 'delivered' prices... with a box that heavy and that big, you may get slammed with customs tax
Sydneykid...
Sydneykid...
Yep that's right, but not all multi plate clutches rattle. Some have anti rattle springs, they are silent just like a single plate.
Since there are 4 friction surfaces, they wear in a lot compared to a single plate with 2 friction surfaces. So they need adjusting, otherwise there is not enough movement to dissengage the clutch. Nissans don't have adjustable rods, they use a byspass in the slave cylinder to take up the slack caused by normal wear. Refer below.
Unlikely, it is usually all or nothing when it comes to fork movement.
No, but I have never done an S14 (or an S13 or an S15) for that matter. There are however a number of different Nissan fork pivots, some are longer than others. You need to choose the right one to position the clutch fork in the right place.
It sounds to me like you might have had the wrong fork pivot (too long) and that's why you had to machine the thrust holder. So how to fix it? Well, I would try a longer rod, that will at least eliminate the lack of travel question without removing the gearbox. You could weld a short piece of rod onto the standard rod or find a slightly longer Nissan rod from a different model. You used to be able to buy adjustable rods, do a bit of shopping around.
Hope that helps. :)
PS; it is not unusual for R32s' to break the pivot ball, I don't know whether this applies to S14's. You can easily check by looking in the fork hole with a torch.
SK,
Some multi plate clutches require a shortened thrust bearing carrier. ORC and HKS are the two brands i witnessed this with. Nissan make different length carriers as well.
I've never altered my pivot points as it creates more complications as you've mentioned.
Lunatic Dancer,
I think you may have mentioned out too much from the carrier which is ending up reducing your throw.
Did you try giving the system a good bleed...?
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
