Ok, first off, i have 0/nil/no idea bout clutch..all i know is drive and go.. If u knw wat i mean.. Today, went for a charity fund dyno day, had the car on the dyno and first run, clutch slipping in 4th gear, 2nd run, had it run only in 3rd gear no slipping.. Now im on the market now looking for new clutch...i have read the "upgrading clutch section" here, read bout JB clutch, i just want some opinions from u expert first... Car is fairly standard.. Except the basic mods; full exhaust + nistune etc etc.. Car is running 194rwkw atm.. Plans in the near future, high flow turbo, bigger injectors, z32 afm, chasing for a 260-270 rwkw.. So , what clutch would i be getting then with these mods coming along Soon?? And read about upgrading the flywheel as well once u upgrade the clutch?? Anything else that i need to know ? As i want the new clutch in before the weather starts warming up..I prefer if i could buy the clutch in melbourne as i am located in melb.. Cheers guys
https://www.sau.com.au/forums/topic/373883-clutch-slipping/
Well you need to tell us how much you want to spend, and whether clutch heavyness is a issue for you. Im using a exedy HHHDB for 300kw and its up to the task but is a bit heavy to drive on but for its price and the power it handles its hard to beat. You can also look at NPC clutches they are known to give good results or as you said the jim berry have a good rep for taking whatever power you need one for and still are fairly soft and driver friendly.
In regards to the flywheel it is not a necessity to upgrade you can just machine you standard one but if if you want to go for a new lighter one then yeah thats another decision for you.
https://www.sau.com.au/forums/topic/373883-clutch-slipping/#findComment-5964643
Money is not an issue, i just want it to be able to handle the power im getting soon, or for now 200kw.. I dnt want it too heavy.. I want something similar feel of the standard clutch would feel..And do i need to order these clutches over the internet? Any convenient shops around melbourne that i can just buy it , install , and drive out...
https://www.sau.com.au/forums/topic/373883-clutch-slipping/#findComment-5964707
Ring NPC and talk to them. They are really helpful and they make a great product
Have had my NPC 10" sprung button clutch for over a year now and it's a great clutch. It's softer then the exert cushion button I used to have and bites unbelievably well. It is still a button clutch so it takes a bit of getting used to but it's not to bad around town where I live. Also have a billet flywheel off them which is good as it has cooling slots that direct some air into the centre of your clutch.
If money isn't an issue then maybe ask about there twin plate cushion button. Sounds like a good product and doesnt cost much more then getting the single plate and a flywheel anyway (from memory)
https://www.sau.com.au/forums/topic/373883-clutch-slipping/#findComment-5965037
My standard clutch gave up at 200rwkw... Replaced it with a genuine excedy cushioned button and couldn't have been happier for a daily, it feels the same as stock, is rated to just over the 300rwkw mark and is a good all rounder... Any clutch place can get one of these and I fit mine in a couple of hours with a mate (plus allow an hour or so for a flywheel machine)... Was about $1300 back in the day but costs have come down I think...
https://www.sau.com.au/forums/topic/373883-clutch-slipping/#findComment-5972058
NPC organic is something like $700 delivered, good for 300kw, feels like stock clutch.
Mine was about $730 but is a 10" button instead of the normal 9.5" so is good for 400kw
There good to talk to anyway, will help you find what you need
https://www.sau.com.au/forums/topic/373883-clutch-slipping/#findComment-5979107
^^ +1 Just got an NPC 10" HD Organic clutch (300rwkw), thrust bearing and billet steel 6.8kg flywheel delivered for just over $1k.
I believe the clutches are modified (& improved) Exedy items with more clamping pressure and stock feel.
https://www.sau.com.au/forums/topic/373883-clutch-slipping/#findComment-5981002
Just want say thank u all for all the suggestions.. I now have a JB HD clutch, organic, single plate, rated 3000-3300 lbs clamping force, with flywheel machined..rated to hold below 300rwkw.. Will be installed this week.. Cheers guys..
Edited by myRB25DETT
https://www.sau.com.au/forums/topic/373883-clutch-slipping/#findComment-5981401
  • 3 weeks later...
ok check this out i bought myself a H/D Cushion Button excedy clutch about 3 years ago for my drift cat
i go to minimum 9 events a year
so a ruff total of 27
pulled out motor/ tranny last week to do some work
i pulled out the clutch and measured the meat left on it
i emailed excedy and asked what was on them brand new
turns out i have %90 Left on there
so i blew a gear box did 27 drift days
a massive amount of clutch kicks and the good old single plate button has lived
Btw my specs are im running 320 rwkw's out of a rb25 with close to 600nm of torque
https://www.sau.com.au/forums/topic/373883-clutch-slipping/#findComment-6006171
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
