i put my 25/30 together on the weekend with a genuine nissan rb30et head gasket and ARP studs for a rb25det head. i did a cold compression test after i had set the timing yesturday and i only got 30psi. the head is rebuilt and the bottom end came from a running motor. the studs were torqued up to 88nm as per the rb30 service manual.
all i can think of is that the nuts on the arp studs are wound all the way down and that the gasket isnt sealing properly.
or is 30psi normal for a cold test?
cheers
Edited by the_jack
https://www.sau.com.au/forums/topic/374518-compression-test/
when i put the head studs in i wound them all the way in then backed them off a turn but then when i put the nuts on they went all the way to the bottom and bound up so i wound all the studs all the way in.
Are you guessing that the pressure is seaping out across the thread of the stud? I want to keep eye on progress here, I feel I could learn something.
If it was me, I would have suspected timing could be off. You could do a leak down test before you take the head back off and see where you hear the PSSSH from. Even if timing is off one degree, you will get almost no pressure at all.
What I would do is a leak down test on the first cylinder(I'm guessing you are getting 30psi read across the board), listen to the air psssh. If its coming from the exhaust or air filter, your timing could be off or something more. If you take out the plugs from the other cylinders and can hear air coming out of the next piston, you know the gasket isn't sealing. Also what you can do if you do decide a leak down test, get some rubber hose and run it around the head gasket around cylinder one and listen if you can hear the air pssshing from where the studs are. If you can you know the issue.
Also after quick searches etc, the arp stud kit looks only to come with one set of washers...
Edited by SargeRX8
leak down and figure out where its coming from. i'd also get another set of washers anyway, you really dont want the nut on the end of the thread. not that it'd give you low compression but you should use 25 torque figures for the head bolts/studs not 30e(t)
Don't pull it apart. Pinpoint the source first. You'll ruin the head gasket as its been crimped already. You've also over torqued them a little(I don't think it should impact it that much though...) so you want to be careful the bolt isn't weakened by fiddling with it too many times. Its MUCH MUCH easier to do a leak down then it is to rip the head off.
Yeh Mafia is right about the torque for those studs. ARP states 80ft/lbs which is about 108nm. You have under torqued them if you did it to 88nm.
If its the head, sometimes when they cut the seats, they dont seal properly until the engine is run for a while and then they come good. Unless ofcourse the valves were lapped in before assembly.
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
