I was curious as to what the most power made on a stock RB26 crank is? I actually have a 25 but I haven't found a very high hp one and figured the 26 crank is as close as I could get. I'm building a drag RB25 and am keeping the stock crank as I don't know of an aftermarket 25 crank. I know rob@rips has made alot of power on a 30 crank but wasn't sure how well that would translate to a 25.
https://www.sau.com.au/forums/topic/374796-most-power-ever-on-a-stock-rb-crank/
  • Replies 48
Damn looks like I'm aiming for well beyond the max then as I'd need around 800Rwkw to be competitive in the class I will be running. Has that been because they break beyond that or because people who are looking to make more power get aftermarket cranks?Here is my build:
http://www.gtr.co.uk/forum/155003-drag-rb25-s13.html
Edited by jimefam
where did i say 600 was the limit? :blink:
Your build thread is quite interesting, what block modifications etc are you making?
There is no mention of it.
You didn't. And I didn't say that you had said it was the limit. I asked what the max power made was and you responded that well beyond 600rwkw which I assumed meant under 700 or else you would have likely said beyond 700rwkw. I proceeded to ask if that was the max made so far because they broke or for some other reason. No limit has been implied by either one of us although that is what I was trying to determine.
cant see why 25 and 26 cranks wouldnt be just as strong if not stronger than 30 cranks. they can handle more power than you'll ever need
Thanks for response. It's good to have a source where to ask questions since info on these motors is very limited in the US. I've received some great info from experts and in particular Paul from Red R Racing has gone well beyond the norm in providing me with valuable insight and R&D based on his experiences. That's one thing that always impresses me is how selfless people can be when I'm not doing any business with them and they still give me a hand on things they make a living off of.
Well i can only tell you that which I've seen first hand.
Others might have seen cars go over 700.
Im not going to tell you 1000 if I've not seen that consistently... That would defeat the purpose.
Plus you never said how much you wanted in the first place. Had to start somewhere.
Really I will have to see what it takes to be competitive in X275 at my minimum weight. A top run in that class is 4.80's in the 1/8 and I will have to weigh 1295kgs so we'll see how much power it will take for me to accomplish those times. I have to admit I'm surprised to see such high numbers on a stock crank as I saw so many aftermarket ones and even Nissan created the N1 crank I assumed that some weakness must have existed. I did get an email back from Paul at Red R Racing and he also confirmed that he had made 1350hp on a prepped stock and had spun them to just over 11k so apparently I should be fine.
You could argue he isn't being selfless because by him doing what he does he gets massive respect on these forums and people will always keep coming back. I don't think he does huge volume though so I'd say he genuinely just does it for the love.
Lol I suppose one could look at it that way but to be honest with you Paul knows that at least for the foreseeable future he can't expect any business from me(I'd already ordered everything and found a local shop to do the machine work.) and yet he's still been not just willing to answer questions but to offer up advice without request from me. Not everyone has been so forthcoming and others who would have similar motivations as what you suggest haven't been as helpful. Regardless I appreciate the help of anyone who will give something for nothing.
has he really? he's built an RB26 running 1350hp on the stock crank revving to 11,000rpm. i'd love to hear what car it's in. i've never seen or heard of it. not that i've seen or heard of every car ever made but the ones making 1350hp that are built in my own state by someone I know tend to stick out...
BTW there is no such thing as an N1 crank.... N1 engines use the same crank as all RB26s do. there are only really 2 types of crank. early model R32 (short oil pump drive) and then every thing else (late R32, all R33, all R34, N1, Nur etc) which has the larger oil pump drive. but apart from that small difference even the two types are the same.
Really? Just the one crank? Well I must be mistaken then but I was basing my info off of nissans own info. On this page they show two cranks:
http://www.nissanparts.cc/catalog/?section=958#3232
Oh and it was one car that made 1350hp and another that revved to 11,000 not both. Although I didn't ask what the one that made 1350hp revved to. Do all the engines he makes stay in your state? Otherwise I can't see where being geographically close to him would help you know all the engines he's made.
It will handle 1 billionty millionty zillointy killer wasps...
what's with the stoopid 'how much hp can my m8 bolt handle' threads???
Hey genius you don't like the thread topic, don't click on the thread. It's not an idle question either, cranks in general aren't indestructible and I'll soon be in a position to take one to a power level most cranks would fail at.
Edited by jimefam
You mean these two, correct?
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
