Does it matter if it's good or not if you already got one? It may not be the best out there, but it will make numbers like 370 flywheel hp. Been in a car with this combo. Nice torque in the midrange, pretty ordinary top end though, rally car style. Compared to factory turbo it's certainly an improvement. Boost was at 1.5 Bar.
Yes they have a 76mm 46 trim T04E compressor wheel which is a bit much for the GT28 turbine , it will work but not "spool" as well as some of the other compressor wheel options .
HKS replaced it with the GT2871R 52 trim and with their housings call it GTRS .
AFAIK they both use the same HKS turbine housing which can take any Garrett cartridge using the GT28 NS111 turbine . So , GT2860RS/"GT2530"/GT2871R 48 62 56T and the HKS "GT2535" .
A .
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
