I've got one and had it installed by Blitz? (Pete..thanks!!!) the other week and there's a definate difference.
There's nothing wrong with em and if your talking aboiut the flying dump from flying international on ebay, they are quite cheap.....and if i'm allowed to say, cheaper than the previous mentioned. Just send him an email and he will give it to you for the starting price on ebay without having to bid. I sugest buying the heat wrap off hjim too.
Catch ya ! Birnie :(
Hey skidmark ive just put one on my 200, huge differance. they say 17kw at the wheels increase and a one psi jump inboost. ur welcome to come have a look at mine if you want just pm me. I also got the heat wpar too
Skidmark, the flyin and BATMBL ones are the same thing. I've got one, and noticed a significant increase in response and power, although I went from stock to full 3" turbo back. Very quick postage through flyin performance too! Have a good look around though, cause the day after I bought mine, there was exactly the same thing selling for $70 less!
There's this company called Flying Performance:
http://stores.ebay.com.au/Flying-Performan...e-International
They sell a dump pipe that comes from the same source as someone on this forum.
Therefore the pipe is called a 'Flying Dump' as opposed to a HKS Split dump or something of that ilk.
T.
Guest INASNT
T.
whats meant to be so good about these? They dont even have seperate wastegate/ exhaust pipes, looks the same as the stock one.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
