Hey zoom appreciated hearing your experience with the GTX mate sounds like its a good thing cant wait till next week to get my car back and see how hard it pulls.
Sounds like your car spins wheels a hell of a lot haha just wondering what kind of diff and suspension mods u might have? Have u had and boost control issues with the smaller actuator?
No diff work just the suspension, just as whiteline swaybars, whiteline pineapple kit, camber upper bushes front and rear, tein super street (setting at 345mm front arch to wheel center). The rear camber i set to -0.5degree and toe in 1mm to give me more traction, while the front -2degree with 2mm toe in and maximum castor.
Never had any problem with the garrett 1 bar actuator. my old hks ecv3 seems to hold the boost pretty steady to redline, may drop like 1psi. It seem like come on boost reasonably quick.
previously when i installed the pomcams while with the gcg highflow, i have gained 400-500rpm. I don't know if the big actuator can actually bring the boost on earlier.
Got my car back yesterday unfortunately i didnt get a dyno sheet because ive got a boost control issue that i need to sort out and ive also got an idling issue :rant: so the tune isnt finished yet
Yuvaz said i made 270kw @ 20psi which was a lil disappointing number wise BUT it feels unreal pulls like a freight train is very responsive and the sound is amazing!
Does anybody know where i could get my hands on some English instructions on how to setup a HKS EVC boost controller?
Haha nice!:rolleyes: 320kw its a big juicey number but how long is a unopened rb25 gunna last with that kinda power? I have heard that the 250-270kw zone is the safe power limit? (so to speak)
mate some are good some dont last long..... i am from a drifting background so u can understand how we treat rb25s...(badly)
some of the racing guys have been making 550hp atw with unopened RB25, e42, gt35r, plennum and cams for 2 seasons... and i know of a couple rbs that have been making 450hp on pump fuel for 4 years....
its only like $1500 for a new one every 4 years.... but its a fun 4 years
Thats not a bad number at all Micko. Remember its just a number.
What is the idling issue? Is it mixture related? Remember it was playing games with us when i did the quick road tune
Hello miss sexy :P yeah the number doesnt mean a thing when the right foot goes down mate cos its a beast now haha! I didnt have the rocker cover breather plumbed into the suction line so its probably sucking air from there so thats something i gotta do this weekend to try sorting that idle out & so the process of elimination begins :blush:
It feels really good considering its not tuned properly Yavuz said hes got some holes to fill down low in the tune yet but once ive got the boost controller sorted
i set the controller to 15psi and i get around 19 or 20psi boost :spank: and that breather line hooked up it should be an hour on the rollers away from the tune being finished properly :banana:
Well ive had a few days of fun at this stage lol and im nowhere near those numbers so hopefully it will be 1 of those good ones that hangs in there for a while!:whistling:
Thats unreal 550rwhp on a stock motor thats awesome!
Testimate to how good nissans little RB's are!:worship:
Haha Andy exactly! Who cares if you got a car that drives like a million bucks on and off boost and puts the power to the ground nicely????
Its all bout the number isnt it?:blink: HAHA!
You can't dick schwiiing unless you have a bigger number Mick.
Who cares how it drives....sif that matters. :nyaanyaa:
well its not much fun telling people you have a 4 inch dick,
even if you can use it...lol
Haha now that would be impressive! yeah should be interesting i think you need to jump behind the wheel of my car when u get the chance Andy
4" across the eye?
Hopefully we can overlay our dyno runs in about 2 weeks.
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
