Listen to them where though?
I've found that listening in-store (this is going back 10yrs now) wasnt the best way either because of the installation into the walls varies between brands and often specific brands design it so they sound better "instore" so to speak as the area you are in is much larger etc.
End of the day I ain't no audio nut :)
This is more to improve what is basically the worst set-up known to man. So anything i guess could be better!
Will def look @ sound deadening the doors though, 1KG here/there isn't really an issue.
  • Replies 44
in-store is fine, as long as you're aware of what you just said. The cavity behind wall speakers varies and may have fewer reflection problems than a door mount but especially in the same shop it will give you a good relative gauge of the sound.
Good quality speakers may sound thinner (ie less bass) in store because they're designed for a door size cavity not a wall size.
The more reputable shops (of which there aren't that many) will have a speaker wall that gives each speaker a typical door size cavity behind them.
At the end of the day the general rule is $ = quality. But I'm sure there are some shonky products that aren't worth the asking price so use your ears to find what sounds good to you.
Actually, the best thing to take is a CD with female vocals on it. Any speaker can sound OK with lots of bass on instrumental stuff or doof doof, but female vocals in particular are midrange sounds, not much bass, and they have more audio information right in the crossover region between woofer and tweeter. Listen for clarity and natural sound in the voice. This will tell you that the speaker as a whole is engineered well (cone construction + crossover design) and not just a cardboard circle that flaps around and creates wooly bass.
The best advice I can give is LISTEN to a whole load of speakers. It takes time, but your ears will tell you what's good and what's not. Take a single test CD with you that you are very familiar with.
I did this years ago and realised the following: Yes take a mix of what you like in the same format you would listen to it in, MP3 compressed sounds way different then a Shefffield lab gold CD. but remember the sound boards sound shite anyhow in most cases and most have lots of background noises from other departments , some have amps, some dont ?
Pioneer speakers are shit Really ? I doubt you have had a look at the new SQL range from Pioneer ? Ive had old pioneer's last longer then my car. decent for the money in most cases
Sony speakers are even worse Agree
Alpine is meh Depends on the range but decent overall / overpriced
Clarion is meh depends on the model, some are fantastic , some are blah
Boston Acoustics are really nice -> bought these ones Agree but watch the specs on Bostons, they are nortorious for testing SPL @ 1 watt at half a meter, not 1 meter but still sound nice and prices have come down since I sold them
Beware the path of audio nirvana though. I spent too much on the speakers in my car currently :PWhat brand if I can ask ? you can drop 10k in a pair of splits alone if you go higher end ? is it worth it, NO !!
like anything car related its a bottom less pit of money..haha
Alpine is meh
Clarion is meh
Curious what alpine speaker you tested was shit ? Because TYPE R and X is def's killers.
I use to have Rockford Punchs they went heaps good. but Type R was ment to the be matching form to punch.
Rockfords are decent, I started installing those back in 89...lol , and built a few rockford demo trucks.for CEA shows in vegas like most brands, they make entry level and top of the line,
but to get back on track he wanted a system for dirt cheap and sounded decent for the cost. ????
Rockford agaist Type R ? Alpine just has a better market share and is a much larger company but both companies make good stuff . and both of the speakers you mention are "MID RANGE" from the company. not high end
rockford is part of a company who makes some of the best brands around ?
Type X splits are the same as a other notable companies with minor tweaks. type X cost a bit more then he wanted to spend..lol
Ash i work part time in car sound at JB hifi
you can pick up a headunit with usb/aux for under $200. get some Alpine type R splits which sound awsome for about $200 mark and some JL audio c2600x for the rears for about $170ish
if you need anything hit me up and il look after ya
Which shop? Ill come down and break your balls and check out every Deck in detail :D
Deck is the most important part as it's gotta be functional and work well etc. Hence i need to "hands-on" and try it out.
Thanks Ash this is exactly what I am looking for at the moment. I still have the standard headunit and I think I have finally cracked it also.
I have found the Pioneer headunit I want. What would be the next step down in speakers from your $200 and $170 options James? Something around the $150 and $100 range and preferably not alpine as none of the online stores have em.
Maybe some jl audio tr-600 cxi there $163 I can easily do them for under $150, might.be around thr $110-$120 mark for rears front splits got kicker 11ds56.2 $198 I can do around the 150 mark mayb bit less..
But in all honestley from my point of view it doesnt matter if you get $500 speakers or $50 ones, if you dont run them off the appropriate amp, your basically just going to get the same quality if you run them off any headunit
No u dont lol. :S wtf... U can run a good set of speakers off a headunit and tune the headunit to run no bass off the speakers. Then the good speakers will go heaps better then ur typical shit speakers. Thats what i do for my daily. I run a amp and sub and let that be the bass.. But theres no way what u just said is true. I've done heaps of installs. just need a half decent headunit that will tune ur typical bass , treble and mid etc etc. Goes hard and sounds great... I've got Rockford Punchs and Powers run off a Headunit.
yeah obviously its not gna sound AS good as a amped speaker.... but it Def still sounds heaps good without if u go the right way about it.. If u run bass through speakers and the headunit then theres no way ur gna have quality.
Edited by sultanaz
Mmm thats jus what ive been told, but from what ive gathered..you buy yourself some 100watt speakers..all headunits only put out 50 per speaker (except sony 52) you wont be getting the full patential, yer it will sound ok..but extra couple hundred get a amp. But from ash was saying he isnt getting a sub..so like youve said, you can tune the speakers to not put out bass..that wont work with ashs situation. But yer all in all id rather get a cheap 4 ch amp
got the following in my 33 GTR
- Pioner head deck... mp3/USB/SD card etc etc--- $210 i think
then waited for the big audio shops in sydney to have their big midnight sales. Told the guy that I didnt want a sub flying in the back. This guy was a clarion rep and he said if u dont want a sub then get the following:
- Soundstream splits-- RRP ~$370... got em for $200
- Soundstream 6x9s (these have 2 +/- inputs that split high and low frequecy) - RRP ~420... got em for $230
- Soundstream Lil Wonder 4 channel AMP - RRP ~$450 paid $270 i think
he threw in an amp wiring kit for free
mounted the amp next to the battery above the pump.... took a weekend but did it all myself
sounds mint... the 6x9s are awesome... no sub n still get a good amount of bass :)
i think an AMP is a must to get the best out of your speakers
What I got in mine..well waiting to be fitted..
Pioneer mvh-8350bt
Jl audio c2600 splits
Jl audio c2600x rears
Jl audio xd700/5 amp
Jl audio 12cwo4 sub.. Somthing like that
Kicker 4 gauge wiring kit
Kicker rca's
Rrp $2400
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
