Hi
Im getting ready for some decent mods to go with e85 later this year but I rekon I'll need a surge tank. Im hoping someone has some dimensions for an under car dual pump surge tank. Even if someone knows how much available space is there under the rear seat on a r33 that would be sweet
Thanks in advance
Paul
https://www.sau.com.au/forums/topic/375759-r33-gtst-under-car-surge-tank/
Thanks for the advice guys.
It seems every tuner I speak to is recomending a surge tank and dual pumps. Is this over kill? I wouldnt mind saving the money if its not needed
Cheers
you then ask how many E85 setups they've played with....
i had a GTT before my R, and with a similar sized turbo to what you're planning on running and E85, all i had was a drop-in Walbro. No issues what-so-ever, track days included.
save your money, you don't need to spend it on such an elaborate setup
Thanks again guys. Rekon I'll give it a miss untill it seems I need it. Now for the age ol question of the 3071 or 3076, been trying to figure it out forever and keep changing my mind lol. Any advice?
Ditch the surge tank, I almost spent big money on a setup only after reading opinions and facts. Unless you are driving around like a dickhead on your last quater tank, you'll be fine. I don't let my car drop far below half.
Ditch the Garret, Hypergear turbo. Designed, tried and tested for the and only for the skyline.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
