I am planning the next upgrades for my car and one thing on the list is a decent clutch thats strong enough to hold anywhere from 280-300rwkw and is bearable to drive daily and won't blow up my gearbox.
Car in question is a R34 GTT with a built bottom end, currently pushing 245rwkw but stage 2 will be happening early next year.
Please list down what clutch you have on your car if you're running anywhere in the 280-300rwkw power range.
Clutch type/brand/clamp pressure etc:
Lightened Flywheel: Yes/No (If Yes, Brand)
Driveability: 1 to 10 (1 being soft as stock, 10 being stiff hard as a rock)
Price:
Place of purchase:
my car will be daily driven with the occasional track/drift/motorkhana day (maybe 6-8 days a year)
so i dont want something that will give my left foot some new muscles or something thats got so much clamp force it'll blow my gearbox but it has to be strong enough to withstand up to 300rwkw when the pedal is dropped.
im running a R34 RB25DE gearbox which i believe has the same internals strength as a RB20DET gearbox.
Please don't advise to get a RB25DET gearbox as it is already on the to do list once my box blows.
Look forward your inputs.
Cheers
https://www.sau.com.au/forums/topic/376014-clutch-talk/
jim berry you'll find to be the most popular to drive daily. clamp power is capable of handling those power easily without almost any change in pedal force or friction points etc.
so you know, NO clutches can really withstand 7k+ rpm drops for very long, so i assume u just mean now and again to show off (which you shouldn't do on public roads FYI).
https://www.sau.com.au/forums/topic/376014-clutch-talk/#findComment-5997245
That you're going with an R33 box you'll be able to reuse whatever clutch you now purchase. I can offer a modified Exedy Sports Organic that will hold the power you require, I'll send you a PM with details.
https://www.sau.com.au/forums/topic/376014-clutch-talk/#findComment-5998574
hmmm, im not sure about that. once the clutch is engaged the shock will be the same regardless of the clamp force. so only thing i can think of is if it engages heaaaaps faster. but, never heard of that, and JB clutches are well known in high power applications, even with crappy gboxes, so... :S
https://www.sau.com.au/forums/topic/376014-clutch-talk/#findComment-5999958
Sorry but I disagree. The JB clutched car that I drove I wouldnt like in my own car. It was a light switch!
Nismo twin plate. Done, done, done.I have done 40 8000 RPM launches in 1 day and it has felt the same in the afternoon. The same clutch has been in the car for 6 years and holding over 400 RWKW.
https://www.sau.com.au/forums/topic/376014-clutch-talk/#findComment-6000024
um.....what?
Elvis; I know 3 people who bought JB clutches and later regretted it. If you're not fussed on budget get a Nismo twin plate, if thats too expensive get something like an Exedy single - for daily driving they're pretty decent. I think the sports organic was the one Dave has, it's easy to drive but i'm not sure on the power rating so you'd have to check that
https://www.sau.com.au/forums/topic/376014-clutch-talk/#findComment-6000080
Give KB Clutch Engineering a call. He made me a custom 5 puk carbotic button clutch. Ive got the SS2, big power, huge torque, lighter than my old "OE replacement" clutch was. $380. 380 for a f**king clutch to hold 300rwkw and 700nm torque! Not too sure how long these carbotic clutches last but he said it all comes down to the driver and how its used. My car is a daily, this clutch has been in there for almost a year now and no issues here. When this one gives up, I know where I will be getting my rebuild from.
https://www.sau.com.au/forums/topic/376014-clutch-talk/#findComment-6000465
Thanks for the info Steve! ive got a HD sports organic now and i will see how it goes once i up the power but its held my current power fine with daily driving and a few skid pan/khanas. i like the pedal feel on this so anymore stiff i wont enjoy it so much for daily, If my wallet permits i will def go with a nismo but it doesnt :(
SargeRX8, i will give KB a call and speak to them to see what they can recommend.
however i initially was gonna go with NPC but since KB is in Sydney, they will be a better option.
https://www.sau.com.au/forums/topic/376014-clutch-talk/#findComment-6000746
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
