  • Replies 486
Posted Images
According to the BBC, Cal Crutchlow has signed to become a factory DucatiMotoGP rider for the next two years.
The Englishman, with Tech 3 Yamaha since his rookie 2011 MotoGP season, will take the place of Nicky Hayden, who recently announced his end-of-year Ducati departure.
wha.... why?!
with the potential of four bike teams, why the fcuk would you have anything to do with these two bit spaghetti hacks?!
