So today I discovered the present I was left presumably from after the dyno day when I stopped for lunch as thats the last time I drove my gtr. I would have been out of my car for no more than 10 minutes but that was all the time the f**king scumbag needed to hit my car and leave without me noticing. The dent isn't too bad really but the paint scrapes they left are my concern. Anyway a picture tells a thousand words so...
the dent is a little hard to see, as I said its not huge.
So I need some recommendations from people who may have used those dent removal services before or whether its something only a panel beater would be able to fix. I'd really like to get it sorted before the dawn cruise.
Cheers,
-Pete.
https://www.sau.com.au/forums/topic/376247-dent-removal-in-adelaide/
you can use simple Thinners to remove the paint marks, and a small amount of dry ice to pull out the small dent
are u serious??? thinners, ummmm NO!!! thinners wil remove the clear also, just use a gentle cut n polish to get rid of the paint...
as for the dent i use "adams dents".... look him up as i dont have his number handy, my x gf's black astra convertable has the rear qtr kicked
and this guy got the huge dent n scuffs out without a mark left, i was impressed.. all for under $100 :)
any probs sourcing his number im sure i can chase it up for u... hes mobile also
Edited by kh6gtr
So just got the car back from Nick with Dentmasters and its perfect.
I wont bother taking a photo because you cant tell that there was a dent there.
He was very easy to deal with too, good bloke.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
