Hey all, just a quicky.
Im after an exhaust manifold needs to be low mount, needs to suit my GTX3076 internal gate.
I was looking at the HPI ones for the GTST. then obviously theres 6 boost, but duno if they are low mount.
Theres also alot of faf about merged collector? etc etc. are the HPI ones a merged collector like the 6boost ones?
Can anyone suggest any alternatives?
Bit of money to spend so i appreciate any serious advice or experiances.
Cheers
https://www.sau.com.au/forums/topic/376361-exhaust-manifold/
get the 6 boost...lifetime guarentee of awesomeness...
Though you do have to modify a few things.. i do beleive the HPI sidemount will bolt straight up with everything in the same position, Tao just fitted one similar to his car check his thypergear thread..might be a good option for you..
yeah thats why the HPI seems a good option. Do they flow well or do i go for above " HKS cast low mount " if i can find one?
yes they,re near impossible to find..plus you will need a new intake pipe and new dump fabricated, same with 6boob..HPI is your easiest choice but......yeah how good they are I dont know..
You can get your stock manifold honed out as well is another option but none of these are really going to fix your problems much, I honestly think maybe your better off going highmount or swapping that turbo which will cost you about the same as a manifold anyway....i dunno :/
Any manifold you pay less than $1000-$1400 for, you are going to run the risk of it cracking.
The quality simply is not there yet from the China stuff when you subject it to extreme heat, weight etc. They just crack.
Even the RB26 Tomei manifolds crack and you pay $1000 for those! You really need to spend to get quality in the manifold area. 6boost are a SAU Trader, i'd be dropping them a PM if i were you :)
yeah dunno ,they could be alright..I just thought it was a funny thread :laugh:
..thing is any manifold will crack, under duress even the stock on doesnt last long...if you dont mind taking it off every now and then to fix it, which is fine if you do it yourself in the shed on your time off..if your paying someone to fix it you arein for alot of heatache..buy the best buy with confidence...6boost ;)
Stock ones generally are perfectly fine. Rare to see one crack as plenty have been running 250-300rwkw for years without issues.
If they do crack its because someone hacked up to weld a gate on, or had the full exhaust weight hanging.
Hmm IN fact i have discovered that the rb25det stock manifold is not aligned properly
thats there over hand on some of the port
If you ahve a anifold lating around go check it ( stick a good gasket over the top of the ports and see that it don't mach up
i have sen that all the ones i have seen have about a 2 mm to 1mm lip where it is not aligned
problem is you cant just grind it out because the bolt holes are to big and you will loose to much service area
Idea's??
IM chasing response and response only currently have 300 rwkw
with alot of torque and boost curve is about 3.600 rpm Already dont intake manifold But im afraid that making my exhaust runners larger will give me more lag ( granted it will give me more power ) but more lag anyone got info on this
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
