Yeah I wont be making this any more..
Car has been at a workshop for the past week having the finishing touches done before run in and power tune on my new engine.. put coolant in the new radiator today, pressurised the system, didnt hold pressure, check for leaks, nothing apparent. Long story short, during the final check before putting it on the dyno for run in, checked the sump and its full of water..... game over, out it will come. So f**king over it.
  • Replies 412
Its worse considering the parts list behind it and how much has gone wrong along the way. Dropped so much money on this thing and have seen no benefit to date, its really depressing. Think along the lines of sleeved SR with 90mm CP pistons (2189cc..), tomei cams, rb25 box, gtx3071r, 740s, z32 etc etc.
:O
sorry to hear about that Jason.
I'm out.
Car was all loaded, just took it for a spin and lost 3rd and 4th in the gearbox. devoed. really needed to get some me time. damm.
Bring on the next gearbox.
Ill try have it ready for the next track day.
cheers
There is a meet point at Caltax Bolivar for anyone interested at 7:30am - leaving 7:40am SHARP (unless I am late :P )
I will have $1.50 cans of drink for sale out there (Coke, Zero, Fanta, Creaming soda, Lemonade, Lemon Squash, Passiona) , as well as some $1.50 muffins, lamingtons and donuts for those with hunger pangs. More substantial meals are available at the Mallala pub and the IGA/deli in Mallala.
See you all tomorrow for a big one!
all ready :D
Well I am all good to go. Just have to fill the car up and 3 Jerry cans tomorrow morning.
I will be at the meet spot :D
Just haven't changed the brake pads as I am not confident in doing them myself. I have seen it done a fair few times just don't have the confidence to do it atm. Hopefully the current pads will last the punishment. There is about half life left in the pads up front and same for the rear. I have a brand new set of QFM A1RM's with me that I will be bring out to the track and hopefully someone can lend me a hand in changing the pads if need be :D Also hoping that 3 jerry cans will be enough.
Looking forward to this track day :D
Guys, just a quick note to clear any confusion regarding deposits.
The club pays for the track day regardless of who goes or who doesn't.
It's very easy to say that people dropping out last minute won't lose their deposits because it can be automatically applied to a future track day, but imagine if half the entrants did that??
Who then pays for this particular track day?
I hate to be a pain here but we need to be realistic.........if your are dropping out for whatever reason, please try and get someone to fill your spot.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
