  • Replies 412
Watching other people enjoy a track day is like being the designated driver on a big night out. Shit ain't cool.
Couldnt have said it better my self. I was up supporting my brother in his gold 180, was a really hot day so bailed after a couple hours; I'm soft.
Shame about the lack of cars actually driving though..... typical Skylines ;)
did you run andrew? i couldnt manage to get the day off:(
Yeah mate I managed a best of 1:28.01 in the end, but only realised after my tyres had gone to licorice that I had the windows down and the a/c cranking for that session (I only did 2 sessions, and only cos there were basically no other cars running). Still happy with that time!
finaly faster than the 60kw mx5 andrew, congrats... :nyaanyaa:
had a ball today guys, great to have a chat with you all! didn't break anything out there although my CD player has mysteriously stopped working lol...
Shame i left so early, was just way too hot for me though!
My head is full of future mods now (oil cooler, 3076/ nistune yadayada) thanks for the motivation to throw more money at the car lol
had a great day out there, apart from the fuel filler cap deciding it didnt want to seal anymore, once that was sorted car was faultless all day. was really to hot out there, only would get a lap or 2 before tyres, oil and water all got a bit warm, even with all the preventative measures. Still managed mostly 1:24s for the day, will have to check the timer tomorrow when its not raining to see what was my fastest.
so over Christmas seems im working to buy some semis and some bigger/working brakes combo. ah well, the quest to go faster and faster continues
In the tab next to this one I have that set of Alcons I've been eying off for a couple weeks now. And in the tab next to that, tirerack.com.
This can only end badly.
Or well, depending on your perspective I guess.
was a great day
managed a best of 1m26.3s, pretty happy with that. 1 second off my previous best. and considering nothing changed on the car since last track day, appart from more worn tyres.
the safety car was annoying though! :D
it was frustrating to keep boiling the coolant, ah well at least i got a few hot laps before the beeps started
Best track day I've been to, sooo much track time haha.
Heat was causing alot of issues with tyre grip, my ass was getting a little loose out there >_<
Played around with a few things and managed a 1:19.1, looking forward to another sausa track day in 2012! :cheers:
was a great day
It was an awesome track day. Pitty it was hot early on and than cooled down a bit for the afternoon sessions. Would have loved the cooler weather earlier on though.
Thanks heaps for getting the pads changed mate. Really appreciate the effort you put in. I should be able to change it now by myself. Well will give it a go and see how go. I don't even know the best time that I put down. Guess will have to wait till the spreadsheet with all the times come out :D
^^^ hey Krishy, PLEASE tell me you have the timers and beacon!
I grabbed the Box and put the timers in it,there are 7 timers. i havent had a look inside them though. I Did the last session by myself and when i came in not one person from SAU was at Mallala. So I just grabbed the timers, unsure of the beacon. I was using a different beacon that was placed on the start/finish line.
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
