Hi Guys,
I have query about the 3076 that I was sent. I am certain that I requested one with the usual 4inch anti surge, 6 fin compressor wheel with the .60 A/R housing, however I was sent the one in the image below.
It has the 7 fin inlet wheel (T04 wheel I think?) and .70 A/R compressor housing with a 4" inlet.
The exhaust housing is spot on and is the usual .82 that most of you guys seem to use.
My question is if I decided to use this turbo how much worse off would the response be compared to the newer style 3076 with the 4" anti surge and 6 fin wheel?
Is anyone running one like this and what sort of power do you make?
Couldn't find any info in other threads regarding how much power people are making with this turbo with this front housing.
Cheers
https://www.sau.com.au/forums/topic/376583-gt3076-query/
  • Replies 41
that will still make very similar power to the other version, there isnt much difference in them power wise
Thanks Titan.
What about response wise is there much difference?
Another thing will this turbo fit ok between the standard manifold and wheel arch / tower. I have the 10mm spacer. Reason I ask is because of the size difference in the A/R compressor housing size and it looks like It might cut it close..
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6006186
Personally I would return that 7 blade version and get the proper 6 blade version with the 4" ported comp cover...thats what you ordered and thats what you should get...there is some material on here about how the 7 blade versions are inferior...discopotatoe is the guy to speak to...hopefully he'll chime in...
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6006273
Titan is 100% wrong.
I had one, and it made 240rwkw. Maxed. Mater meth, and it made 250rwkw.
Then I got a real gt3076r, 6 blades, surge slots, etc, made 300rwkw. Attached water meth and made 320rwkw.
All on a 0.63 rear housing. Full boost by 3200rpm in 4th. Made 720nm and held that to the limiter.
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6006411
Ye the 7-blade one is not the one you want. Bad and nasty performance for what should be the same price for a proper 6-blade.
I actually thought they'd stopped making them in that option given the choices of 3076s out now with various trims etc.
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6006438
Thanks for the replys guys.
I have contacted them asking to change it to the correct .60 A/R housing. Will have to wait and see what happens.
Dude, you want a whole new turbo with the 6 blades. Not just the cover.
Ask them for the GT3037. Or CHRA 700177-5007
It looks like the one in my avatar.
Edited by The Mafia
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6007050
Yes as Mr Mafia said get the real one which was and still is a HKS spec turbo , only sold through Garrett as well .
The real ones Garrett part number is 700382-10 using cartridge number 700177-7 .
Do it once do it right and think seriously about what he said about the 0.63 A/R turbine housing if lag troubles you at all .
A .
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6007100
I had that issue in NZ back when I was trying to get a GT3076R for my car, all the local outfits kept telling me either its pretty much the same or that it was actually the one I wanted - I had to order from the states to get what I wanted in the end. There is definitely a pretty noticeable difference between the two, using this version would be regrettable.
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6007235
Thats what I told him mate. And now he is going to exchange the entire turbo (1 with the proper 6 fin and .60 A/R) so it should all be fine.
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6007661
A .
Thanks Disco.
I was wanting to still use the .82 housing, my mate has that housing on his 3076 and the lag on that doesn't trouble me at all, so I will stick with that.
And I would have to stick with the Garrett as thats all I can get a replacement for.
What is the difference between the 700382-12 (700382-5012) and 700382-10 (700382-5010) products? Is one 52trim and one 56trim? is there any difference?
Cheers
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6007716
I don't know what reasoning you have for that, but its not the best recommendation you've made imho - especially after having had both myself. The .82 only loses any noticeable amount of go below 3000rpm, where isn't a place RB25s are "about" anyway. Above there the .82a/r feels nicer, is nicer on the engine (Mafia needed WMI to suppress detonation, I and others have battled boost creep with .63s) and naturally is capable of more power.
I never looked back from upgrading from the .63 to the .82 - though again the OP has obviously also experienced a "real" 56T with .82a/r hotside and knows how nice a setup they are to drive.
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6007757
I just sent the incorrect turbo back to them and told them I want the real 56T one which had the part number 700382-5012
I also told them to stick with the .82 rear housing. I wanted to keep the .82 housing as it has the potential of more power if I desire it.
https://www.sau.com.au/forums/topic/376583-gt3076-query/#findComment-6008036
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
