Hi Guys,
just wondering how many of you have replaced the engine fan with a Thermo model instead. For a daily driver, wife to work and back... Me having some fun on weekends..
Did a search for Options and this looks like the go..... Any preferences opinion on this?
And if so ball park cost.....:thanks:
The clutch fan is almost guaranteed never to overheat the car. There is drag on the engine but it is fairly idiot proof compared to some of the issues that can come with thermofans (from appropriate shrouding to decent thermostat control).
There are numerous threads in forced induction from memory on the pro's and con's.
To go against the trend a bit here I have a 16" Davies Craig & have never had overheating problems be it in heavy traffic, on the dyno, etc, etc
So many people on here (not saying the guys above) make it sound like it can't be done without issues but like anything, if done properly, it can...
I hope my post didn't come across like it can't be done, it can. However you want to go in with your eyes open as there are potential issues.
I would love to remove the clutch fan for a reliable thermo but last time I looked (admittedly a while ago) I decided it would be cheaper and easier to go with another stock clutch fan.
What thermostat are you using wlspn?
Im using this to control my thermofans.
http://www.spalusa.com/store/Main.aspx?p=itemdetail&item=FAN-PWM-V3
On my 180sx I used ba falcon twin fans controlled with a greedy unit. It took temp reading from the factory ECU sensor. It controlled both low and high speeds of the fans and when aircon switched on. It lasted on there about 2 weeks before I replaced it with the clutch fan.
The temps always fluctuated within 10 deg where as the clutch fan keeps them within 3. The factory clutch fan is a heap more consistent and easier.
I don't think there's a Thermo fan on the market that can push the amount of airflow a clutch fan is capable of pushing.
I've used thermo setups before, and eventually gone back to the old clutch style fan. Simple and effective.
Yep, exactly what I thought easy and simple.
My 2009 ford ranger still uses it so... Why not.
@ 165 for a new one why not? Anyone had one of these go die?
Would love to know....!!!
No, as I said in my post, that wasn't aimed at anyone in this thread or anyone in particular, have just seen guys on here stating that a thermo will always cause overheating, etc & it's stupid to use one.
Just wanted OP to realise it can be done but as you say there are things that can go wrong or be done wrong...
When I first fitted the thermo it was due to cooler piping & I preferred the idea of that rather than removing the standard shroud or trimming blades as some people do.
My cooler setup has now changed & I could run the clutch fan again but currently have no reason to as temps are very steady under all conditions...
Nothing wrong with the clutch fan. It does its job superbly & is basically idiot-proof.
Fan is controlled by my Haltech (through standard temp sensor) with an over-ride switch
Edited by wlspn
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drive beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
