  • Replies 103
Yeah nice pics SKY031. There were heaps of those going around, worth the $20 bucks :D
Damn I missed out on that 617 rwkw run! That means with the NOS he gained something like 100 rwkw from last year?! That is going to be a hard figure to beat.
Good to hear the Dyno is up and running again tho. Didn't even end up seeing any dyno run at all. The only thing I saw was the BMTS15 making noise on it :)
https://www.sau.com.au/forums/topic/37730-mas-04-pictures/#findComment-759422
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
