Ill be in sydney next weekend fitting mick o's gtx3071. If u want i could take a look at it then.
Sounds good man, you will know here and I'll probably sms you if I've fixed it otherwise shoot me an sms when your down I can bring my car up.
  • Replies 122
I was thinking of something. If I built a small circuit consisting of a few LED's ranging from red to yellow to green which will receive the AFM voltage signal as the input and work in such a way that when the volts are low the lights are red and when the volts and air rises the lights will go to yellow and green, could I use this as a clear display for me to monitor when I am getting effects of reversion to determine if its an issue? I don't think it will take long to make and I should have all the parts I need. I can just keep my eye on my power fc hand controller afm voltage and see what happens.
Or just monitor the signal with a multimeter lol. Better yet an oscilloscope but I doubt you have one of them lying around.
Surely the powerFC software can graph AFM volts vs time though? That would be the easiest way to see.
I has an oscilloscope which I found years ago lol it's been binned though. I might invest in some power fc software. I am fairly certain it can log afm signal against time and rpm. I've got a multimeter but the fluctuation might be too quick I won't see it. With the power fc I can reset the max readings the second I back off the throttle and then check them again. Damn it would be sweet if I could get some power fc data logger on my phone lol. OdbII has it and you can use bluetooth too dammit lol.
Coil packs failed on me. Stock ones are back in there. Damn yellow jackets, lets hope they can get replaced under warranty. Second set to fail on me :( I haven't tested if this fixed my stalling or lean popping issue but it seems everything came at once so lets try iron them out.
Spray the stock coils with CRC urethane seal coat Sarge.
Ill do this, sounds like a mint idea too. I'm using Nitto tape, good shit but under that heat it does dry up pretty quickly.
Damn and i was thinking of yellow jackets after readin some reviews of them., now im stayin clear, ur not the only guy to report their failure..
Don't get me wrong, they work. They work awesome, it just seems that maybe the heat in a modded engine kills them early. Maybe 19psi is too much for them. Could be many reasons but I can tell you the warranty and service behind them(from performance wise) is second to none. Spoke with him today and he offered me a full refund or replacement set. Unfortunately I think I am going to take the refund then invest in a set of spitfires. Looks like the stock piece is holding pretty well so far too. 15psi on the drive home no miss.
So the issue seems to have been coilpacks?
Would be good to get it out there.. I was thinking of getting a set for my SR
well no, the coil packs were my latest problem but I'm still having issues with strapping and idle and cruise conditions... I spoke with performance wise and the highest failure rate is only with series 2 coils. Apparently the coils might have an issue with the dwell time of the series 2...
you guys figure this out yet? its not hard. its pretty obvious what is going on here.
Not yet, its only when the car is warm it lean pops. Please man if you got any ideas let me know.
I have many ideas.... but lets start with this...
Warm the car up, make it so its popping on idle... then... go to the petrol station, don't stop the engine and fill the tank with 98 to the brim.
Post back results.
Post back results.
Isn't that dangerous lol. What should or shouldn't happen?
Do you have your PCV connected to the Plenum? Make sure that valve is still working
If it is still connected do your cam cover breathers still connect to the intake pipe after your AFM?
It is still connected and was replaced with a new piece as the old one broke during replacement of the injectors. I had no issues with the car until I measured up a new intake pipe. I did NOT fit a new intake pipe it. Merley measured up a new pipe then put everything back together and its been lean popping and stalling since. Also noticed my fuel cap isn't going pssh anymore and noticed fuel fumes coming from the fuel cap again ffs.
Ive got my intake breather hooked up to the exhaust breather(like standard) then fron the exhaust side to a sealed catch can then back to the turbo. Below is a diagram of how shit is facing and what not.
Edited by SargeRX8
just go to the station, fill the car up while its popping. after you put a fuel talk, does the popping go away?
also take picture of your intake pipes and post them up please.
As long as you don't spill petrol all over your exhaust I can't see the issue, no more dangerous than normal I'd say, it is just a precaution in the odd event you have arcing in your engine bay and there happens to be close to the lower explosive limit concentration of vapours in the air, basically a 1 in a million chance.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
