  • Replies 199
Guest dmallison
I had PB's all round tonight. Still could've gone better, and on one pass I almost did! Was on track for a 12.2-12.3 until.....
Howdy Matt It was my daughter who was in the torana at the drags, am very happy to say she got out of it with only a broken wrist and lots of bruising. The car had full cage and harness and stood up very well in the crash. She has a GTS-T series 2 on its way from japan at the moment how ironic ! Would like to have a chat about the crash with you, my mobile is 0417898512. Thanks everyone for their support.
Regards: Darren
I had PB's all round tonight. Still could've gone better' date=' and on one pass I almost did! Was on track for a 12.2-12.3 until.....
Regards: Darren[/quote']
G'day Darren,
I replied to the PM mate, but just quickly...
I'm really happy to hear she only sustained minor injuries. It looked like a very scary ride! Please pass on a "get-well" from the SAU crew.
I hope the damage to the Torana isn't too bad? I certainly looked like a fair amount of panel damage.
Cheers,
Matt
Matt, can you let me know how good a job he does, as I need to get mine done too, and also what are his prices like?
He did a bloody good job mate! Very impressed and would happily recommend him to others. He charges $55 a corner, and he comes to YOU (home, office etc...)
He heats the paint up first and then uses the hub roller to roll the lip completely flat. There isn't so much as a single crack in the paint on the very edge of the guards, or externally either :D Up inside the guard on the internal section of lip that gets folded up the paint copped a few chips (to be expected with a big roller going over and over it) but other than that it's perfect!
We loaded up the boot with a few large people and got the arse end squating as much as possible. The 275 Nittos fit without a drama now, even with very little neg camber (-0.6) :)
Pity I didn't get a chance to see just how much of an improvement they could give me :D I rushed around like a headless chook (buying Nittos, getting guards rolled, wheel alignment and then washing the car etc...) only to end up all-dressed-up-and-nowhere-to-go :D
I can still spin the Nittos under straight line WOT 2nd gear acceleration :D Having said that though it doesn't light it up as easily as the 540's did. A few repeated WOT blasts soon see a build-up of heat and with it an increase in grip. With less pressure and more heat they're going to be nice and sticky!
Hey Matt,
Any chance of seeing what the rolled guards looked like?
I'm going to be running on a set of 275 nitto's in a month or so, so I'm keen to see what the results of the guard rolling are!
Cheers,
matt
Good to hear he does a good job, any chance of a contact number etc?
Bummer about the drags being cancelled, has it been re-scheduled or is that it until next month? I'm sure your efforts will pay off whatsisname - just think a little while back you were still trying to crack a 12!! Now with some proper tyres and a decent launch, there is no reason a 11 isn't possible. How things change over a matter of monts, keep it up Matt
Chris
I'd love to head over to Heathcote, even just to watch! Unfortunately it's not good timing for me :( Not unless someone has a spare seat in their aircraft (just a quick day trip):P
Matt (Matty Lowth - too many bloody Matt's :D) No prob's mate I'll see what I can come up with re a photo or 2.
Chris, the contact details for 'Slammed Mobile Guard Rolling' are: Jeff Hughes 0401 400 005 He's only too happy to travel to wherever you want :(
Yeah mate it's amazing the gains I've made with my set-up in recent months. I'll probably hang up my drag racing boots if I run an 11.
Oh well guys, be brave and drive over to Heathcote this weekend. Not only will you get a chance to race on one of the best prepped tracks in the country, you will also be able to see the car that bedded in your Nittos in action :)
I'd be more concerned with the weather for the weekend then the drive over. I hope it doesn't rain and ruin it for all the competitiors and spectators alike who made it over from interstate.
  • 7 years later...
just wondering if you still have this photo?
if you do could you send it to me [email protected], really would appreciate it
This is the Torana that came to grief vs. me at AIR (04Apr04)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
