Its pretty dim in the garage.......looks so much better in natural light.....
for some reason this picture didnt upload earlier.....
and thanks mate ^^^ ...this thread is getting loooong !! Bit boring though now because there has'nt been any real big stuff to report....lots of plans though in the near future...so my fingers and toes are crossed !!
So this morning while I was going through some performance imports mags I came across this.................................
And I wanted to do something similar too.............so I went to the shops and could not find a black sweatband so went to red dot and bought three pairs of black socks (will use the other two pairs for work)...and began to do some "art and craft"............
Result............
And on the car................ :domokun:
My attention has now been diverted to the engine bay...............and since I don't want to spend any big bucks at the moment.....I have been doing this...................
Boring old plastic washer bottle...............
After the plastic primer and first coat of paint..............
Made sure to leave a strip so that I can actually see how much water is in there...going to look like this :ph34r: !! haha
Will post completed pics when it dries and I put it back on............
Edited by jez NF
SEEN THESE WHEELS BEFORE ????!!!!..............look what I found them on while randomly on google searching for wallpapers !!!!!!
autumncarsphotographyjapanesetoyotatownvehiclessupercarstuningtoyotasuprasideviewjdm_wwwwall321com_88.jpg
In other news...the container is almost dry and looks yumm.....doing the coolant one now....
See what I mean.....................
....and update....I drove ALL THE WAY TO WORK with my phone stuck under the hood !!!! Silly me left it there this morning when I was rushing to refit the wiper washer water containter thingo before work.......it still "work"s as normal !!!
Edited by jez NF
Did some detailing of the "bunky".........................and then I bought some high temp paint for my exhaust piping.
The front bar and half the bonnet has not yet been done in this picture...........it is surprising what a little bit of time, effort and average levels of detailing skill can achieve. I know this is a terrible picture and you probably cannot really tell any difference unless you look very carefully but a little bit of effort is all it took and man this thing is shining now !!
Then moved on to my car again...........
Tried to get the exhaust off....but when I realized that it was beyond me I decided to give it a shot and paint it on the car itself.......made sure I had newspaper ontop of it as I didnt want other bits to get sprayed too and sprayed the living hell out of it with degreaser first and just went in with the high temp black....could not be bothered with sanding down / prep and all that jazz...it cannot even be seen !!
This is as high as I can get the car at the moment (without axle stands)...so had to make do.
Came up pretty well I thought judging by the general lack of attention to detail and half arsed effort...going to let it idle for a while and then turn off tmrw.....and then take it for a short run to and from work so hopefully the paint will cure and wont peel....intercooler piping is still perfect so hopefully it lives up to its reputation and wont too.
That is the weld mark from when "kermit" modified my exhaust so that it had less angle and didnt burn a hole through my rear bar.
OH and that looks SOOO much better than the rest of the exhaust at the moment !!
So...............pulled the sunshade thingo down the other morning when I couldnt see a thing because of the blooming glare and thought to myself.....there is a great discovery to be unraveled here..........hahahaa.....no I didnt...I thought.....man this is boring !!
Seeeeeeee what I mean...
So I pulled out some of the left over leather trim that I had..............
...and then I became F U N K Y ...........................lol
Outside view
BTW...Happy new year people :)
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
