Hey all so i was talking to this guy at work who is a car nutter (like 40 lives at home with his dad and spends all his money doing up one of his 10 commodores haha)
so anyway he also has a datto 1600 and a 1984? Bluebird, and this is where my question lies.
Apparently the Bluebird is running a 2L datsun engine (not sure which one) with a custom turbo setup consisting of carburetor to turbo to throttle boddy, and at first I'm like wtf is that even possible and then he explains it to me (most of which i didnt understand) and how it doesn't run and intercooler and some other shit.
car makes 184HP at the wheels on 8psi
so anyway when i get home I inform my dad who is also quite experienced with cars, although Im willing to say probably not as much as this guy. But my dad says its not possible....ARGUMENT BREAKS OUT..so on so on hahaha.
Can anyone confirm this please so i can settle it once and for all?
Ill try get pics (he had them on his phone to show me)
Cheers :)
https://www.sau.com.au/forums/topic/377712-carburetor-running-turbo-engine/
  • Replies 47
yes this is possible, from what i understand from what you've said, he's running a in a draw through configuation
Thanks very much, any chance you or anyone can explain this a little more?
also cheers socrates for your input.
yes def possible, draw thru is the way to go. and turbo's have been around longer than every day fuel injection.
my bro used to have a kombi with a setup like this. only issue you have with a draw thru is that your pulling your fuel mixture thru the turbo itself, which can make it a small pain to get tuned and running right. my brother kombi had an SU carby infront of it, seemed to give tyhe most progressive flow.
in your post you speak of a throttle body aswell?? that doesnt need to be there, as the carby is the throttle body in these setups.
Turbo sucks air through the carby. Turbos need to be built with different gaskets - ones which won't break down when they get fuel on them.
Apart from that it's cake. Strombergs are one of the most popular carbies to use but webers are good too, as the above pic shows.
Wow thanks so much guys....this is why i love SAU haha
one more thing, can someone explain how the fuel doesnt explode from the heat generated by the turbo?
Edited by RBert
Not enough pressure and no source of ignition, ie. spark.
Cylinder pressure is up around 150+psi, where as a turbo may be producing 25psi between the turbo and inlet. And fuel doesn't ignite well without a direct source of ignition. Drop a lit cigarette into fuel and it's not likely to ignite.
Edited by Cowboy1600
As above, fuel has a fairly high spontaneous combustion point(with source of ignition), and the heat of the turbo just isn't hot enough on the inlet side.
The fuel actually helps to cool the inlet down by using the heat in the air to vaporise, in a way similar to water injection.
everything above is correct. there have been various cars over the years running carby turbo setups. in fact there was even a turbo VB commodore (unsure whether it was a holden thing or just a thing done by a few dealers). very rare. a mate of mine actually has one of the setups tucked away in his cupboard.
Oh, and your mates car would be an L20B which is a very, very popular engine to do suck through set ups on. They are tough motors. Although for racing applications many people use L18s as they rev harder. You can bore them out to nearly 2L (bore and stroke can go past this but you lose some revs). Again, incredibly tough motors.
I've owned 1600s and 180bs with either L18s or L20bs (and one Z18et which is an L18 bottom end with a twin spark head, EFI and turbo) and if you saw the sheer destruction I tried to force upon them you would be horrified. Simply horrified.
Off topic
Would a Z18ET head bolt directly onto an L20 bottom end with no mods? Sounds tempting.
Definately have a soft spot for the L series engines. Indestructable. Mine has done roughly ~300,000k, odometer stopped at 250,000km - Always gets a flogging when it's driven, but oil is changed every 5000km with out fail - all original parts.
Currently my Bluebird's stock head is off being reconditioned and mechanically cleaned, so much carbon gets caked onto the exhaust ports - it's crazy.
Only reason for the head coming off is because one of the head bolts snapped, but lucky no blown headgasket. Just doing the cleaning and reconditioning due to all the effort taking the head off.
It will, but manifolds are different. They are a crossflow head.
Try and get your hands on an A87 head off an L18. They are the high comp, big port heads and get L20s singing up to 1000rpm harder than stock.
Failing finding an A87, the W53 is next best option.
I had an A87 and a factory EFI head (and complete set up_ in my shed until late last year. In fact I think the guy who bough the EFI stuff off me is selling it again. Check Ozdat
a BLOW THRU carby set up has been used many times over the years, its a matter of sealing the carb up so it doesnt leak boost. . . .no fuel in the turbo that way . . .as for the L series L20B, lots of mods are easy to do on these motors including stroking using Z series parts :thumbsup:
on the L20 discussion, my mechanic mate had a L20 in a 1600. it was bored and stroked. made about 155hp at the wheels (still natro) from memory. only problem was that it kept arcing out headgaskets because of how bored out it was (gasket was too thin between cylinders).
That's great mate, but we're talking suck through.
Z24 cranks stroke them out to 2.4L and they go like hell. But it requires a fair bit of work to get a Z crank to fit an L series.
The world needs more angry Ford 2.0 pinto's and L20s etc imo
and im a Big engine nutter
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
