We're holding another Social Event at Simworld in Carousel on Friday October 7th, starting at 7pm. Please make sure you arrive 15mins beforehand so we can kickoff on time. Everyone who attended the previous event all agreed it was awesome fun, even from the guy who ended up puking (from motion sickness, not the food ) The event will go for two hours, including food from Nandos
For those who don't know what SimWorld is check it out at http://www.simworld.com.au/ These are full simulators, where you get thrown about etc, nothing like anything you've done before. They've got new tracks, and event have a Flight Simulator (Battle of Britain style)
The general format of the event is:
Group 1 - 5min Practice - Course 1
Group 2 - 5min Practice - Course 1
Group 1 - 10min Race 1
Group 2 - 10min Race 1
Group 1 - 15min Race 2
Group 2 - 15min Race 2
Group 1 - 5min Practice - Course 2
Group 2 - 5min Practice - Course 2
Group 1 - 10min Race 3
Group 2 - 10min Race 3
Group 1 - 10min Race 4
Group 2 - 10min Race 4
Final - 10min Race (combined results from Race 1, 2, 3 & 4 will determine who is in the finals)
* Minimum race time is 55mins
** Comes with food supplied by Nando's, and we can have BYO drinks
*** Group size is 9, as there are 9 Simulators
Note:
The cost is $70.
These are full race simulators, not simple arcade games, so it will definitely be an experience.
Please register your interest ASAP, and then make payment so we can lock in your spot, it's first in bested dressed. Please invite family members (friends, wives, older kids etc), as all Simulators are equal, and doesn't require a drivers license :rofl2: We'd like to have this filled with SAUWA Members and there familys/friends, but will open it up to the rest of SAU if we don't fill the spots.
Cheers
Paul
Payments can be made via the SAUWA club page:
http://sauwa.com/product_info.php?products_id=203
Registered Interest:
Spences (4 of)
Greywolf
Paid (15):
GTS-t VSPEC
Dale (Stinky Rooster)
Vocina (+1)
Hank Scorpio (+1)
Corey (turbosloth) (+1)
Ross (Bosszilla)
Tricstar
t-revz (+1)
Blizzerd
Room42
browneye91
https://www.sau.com.au/forums/topic/377738-simworld-event/
  • Replies 128
lol
keep in mind that we have seen your form at the v-power gig. Bring an appetite son, coz there is a large can of whoopass here, and it has your name on the label :P
https://www.sau.com.au/forums/topic/377738-simworld-event/#findComment-6032662
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
