pay for a dyno run for me and ill tell ya! seriously, bug money getting high hp out of an NA engine, extractors did alot for midrange but not alot up top, ive done everything u can do without touching internals and its not real huge gain, id say 15rwkw at the most, run good furl and advance the timing, that makes a huge difference!
  • 3 weeks later...
