Do you want to do the whole car? Or just the affected areas?
Whole car I'd say 150-200 for just a paint correction.
Sections of the car is hard to say, most pros work by the hour.
Also ive heard good things on scratchx 2.0, if you don't want to spend the money on a detail just yet.
Edited by eat_me
Any decent detailer/painter should be able to fix your problems man. You can get different abrasive grade cuts, so prob an aggressive cut will do the trick and if not. a light rub with P2000 wet rub then a cut to bring back the shine will remove slight scratches and your water mark problems. Take it to a few shops and ask some questions. If its a 2000 model car the paint shouldnt be that bad.
I haven't found scratch X to be that effective .. for a hand polish i generally use FI CAP medium and ive heard good things from other guys serious about their detailing about P21S paint cleansing lotion, which is actually made for a hand polish
it works okayish .. but it took me some serious muscle to get even the most insignificant marks out of my paint
i used autoglym paint renovator once when i first got my skyline, i found that to be quite good :)
i quite like autoglym products actually, pretty good for off the shelf stuff
you're not in perth are you? I have tons of scratch X and autoglym paint renovator sitting around ...
i keep buying more stuff before i get even halfway through the last bottle pinch.gif
We use autoglym in the trade. Well the wax anyway. It's good shit and very well priced too...
Def worth a try IMO.
Edited by Even_Flow
wish my workplace did that :(
we use autosmart ... breaks my heart to send a car out detailed with that stuff ...
90% of my products at home are from brands like Final inspection .. only off the shelf stuff i use nowadays is some of meguiars/mothers, or autoglym ... preferably autoglym
in far less time than it takes me to do a car at work i can get a car looking much better and with alot less effort ....
i started off with turtle wax "ice" products though when i first started detailing
Edited by Jonno34
Hey guys,
Is it worth trying a clay bar to get sap stains etc off the car..or a cut/polish?
Doesnt need to be fantastic as the car is being re-sprayed soon, but looks rubbish atm, my black car looks grey/dull due to all the shit on it
Washed it this morning and it looks crap
A clay bar will definately give that black a better shine. More depth persay. As for the tree sap, if it's etched into the paint I'd recommend clay barring the car then use a cutting compound and Ofcoarse seal it afterwards.
You're call will look a million bucks, depends on how much damage the tree sap did is dependent on the end result.
As for the grey look, that will most certainly be gone.
Like it was said. Clay bar = magic :). Haha
yeah just use a clay bar and hand polish mate, if i have any dodgy stains or anything i just hand polish that spot and seal that area back up
breaks my heart to get rid of all the layers of seal/wax that i build up over the months though :(
P21S paint cleansing lotion is good
off the shelf stuff - ive found autoglym paint renovator to be very effective, i used it on my skyline when I first got it, improve the paint condition by millions
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
