Was driving fairly normally, then just coming back home through speed trap area things. Foot to the floor between them, after the 2nd one I noticed the hicas light come on.
I've recently had it aligned, and its fine at 110kmh so somehow I doubt it is that, although google suggests.
Am taking to mechanics on thursday for other things, but what could it be, or what should be checked?
someone mentioned fluids could be low, where is the hicas reservoir?
https://www.sau.com.au/forums/topic/378403-r32-gtr-hicas-light-on/
HICAS shares the powersteering fluid on R32's, the resouvior is near the airbox.
If it's only recently doing it, the simplest possible answer is usually the right one, whoever did the alignment f**ked up badly and made it worse.
power steering fine. they did diagnostics, nothing wrong. so i will take back sometime for more precise tools.
the dude said he had a GTR that had the same problem, owned it 5 years, last 3 it was on...
the other problem is 4WD light coming on every 5th or so time, meaning only 2WD mode. restarting car fixes that... again no fault they could see :S
