Has anyone fitted 19 x 11 wheels on a R34 GTR?
I've been offered a set as an alternative to 19 x 10 but can't really find much info about wheels that size :)
19 x 11s have an offset of 25 & the 19 x 10s have an offset of 15 - so in theory they should have the exact same stance, so should sit right?
https://www.sau.com.au/forums/topic/378587-11j-wheels/
You may have to 'adjust the inner plastic guards if the tyre rubs, especially if it's lower than stock.
Also depends on what width tyre you decide to run. 34's are pretty accommodating for bigger, wider wheels.
Mine are 18x10.5 +18 and 275 width is stretched.
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6038180
did a quick search and found this if it helps? http://forums.nicocl...34-t288174.html spec sheet is down a little bit
Yeah seen that a few nights ago and got in touch with him :thumbsup:
He said they only had to trim the rear liner a bit to get them to fit comfortably :D
Quite excited now about recieving mine :banana:
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6043411
I finally got some tyres fitted to these today & I can now confirm that a 295/30/19 on a 19 x 11 ET25 will NOT fit on a R34 GTR :(
They fit perfectly & look amazing - unfortunatley the car is undriveable as on even partial lock the inside of the wheels are knocking against the suspension :(
I'm hoping to get hold of some 5mm spacers & see if it pushes them out far enough to avoid the arms
A couple of pics of them fitted though, stock wheels have been refitted now though while I search for a solution
Ignore the white tyre fitting crap around the wheels, I need to give them a wash :)
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6063264
They look massive diameter wise in that picture.
How much do they stick out now with the 10mm?
Drive it over bumpy areas and see if it scrubs on the outside/guard.
19x10.5 +12 and 15mm spacers were scrubbing on the rears. Left a nice thin cut all around my tyres.
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6066996
With a 10mm spacer it sits pretty much flush with the arch.
There will be some rubbing, especially once lowered. I think it will be a case of rolling the arches or possibly even Z-tune arches to give a bit more clearance :)
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6067536
damn, pity I didn't see this thread earlier, could have warned you off them...
Anyway, for people searching in the future, I'm running 18x11 +18 and they touch the suspension upright before full lock, so not ideal. I'll probably try and get some 5mm spacers to just get them out far enough to clear, but they're pretty much flush with the guards as is.
Does look good though.... :D
https://www.sau.com.au/forums/topic/378587-11j-wheels/#findComment-6072919
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
