  • Replies 61
Incapable hands?  You come from a what? (laser?) and now into a GTR.  You would want some driver training.
Welcome none the less.
S.
You obviously don't know the laser Scott...
It was probably more powerful than the GTR but could never get the power to the ground because it was FWD.
Leah has lots of driving experience. Anyone who could control a FWD car with that much power deserves to have a nice car.
She's not just some blonde bimbo who knows nothing about cars. I reckon she'd give some of you guys a run for your money.
Hey Leah.... i saw u on thursday night... was sitting against the rail at roma st down the bottom park... i told ur passanger that the car was hot... seen u on the boost forums i drive a grey 32 GTST with a filo sticker....catcha round
