hey guys
Just wondering what the part number is for the front brake pads in a series 2 stagea and how easy they are to get, do sprints or supercheap carry them. and what price would they be.
any help would be great thanks
Josh
https://www.sau.com.au/forums/topic/378624-series-2-stagea-front-brake-pads/
hey guys
Josh
Hey mate you have a pm i carry them at sprint glenelg in the qfm range
I'm after the SD rotors, part numbers 321 2013 (front) and 325 2016 (rear). Could you let me know a price please?
FYI this guy will sort you out.
http://www.skylinesaustralia.com/forums/topic/378654-dba-stagea-and-gtr-rotors-on-special/page__pid__6037978#entry6037978
Before i did my 33 brake conversion i used 32 gtst rotors on my stag. not sure what the dimensions of a s2 rotor is but if somebody posts it up ill see if i can match it up to something in the dba or pbr range and suspension out a price for us SA boys
ausbrake sell them i have a set got them in melbourne ....part number..DB7648A ..and if you keep your old backing plates they will make up track pads for you too....i have a spare set if anyone one from melb wants them .....all the major brake places dont sell them so not even worth looking ...
We've got two levels of Series 2 Stagea pads on the shelf ready to go (no exchange of backing plates required...), firstly, Remsa, which are a high performance European pad that we use as a trade servicing pad for high end Euro sports cars like Porsche, Ferrari etc. To suit S2 fronts are $105 for the set.
The next level up is the QFM A1RM, which is a Ferodo DS2500 equivalent pad, and more suited to a combination of both street and track. To suit Stagea are $179 for the set, and heaps in stock!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
