Mmmm 1300 bucks haha
U doin sump baffles, oil return/breather from the head Etc?
Dan is pretty much making all the decisions lol. I just told him what I want out of the car etc and he will work with what I want :)
I am not sure on what parts are going in just yet I know the basic stuff just waiting on the list to be sent through.
  • Replies 69
....and once I get the problem Ill post in here :)
yes please, in particular oil pump and big end bearing condition. My guess is still on clearance problems causing pressure loss under load.
Put it on the dyno and see if it still drops pressure, will narrow down if its the Gs or some other issue.
Did you ever try this? It will very quickly sort out if it is an assembly problem, or a sump design issue.
Edited by Rolls
I am sure Dan will post in here.
I personally filled the sump with 6l as its the standard sump it still did it, so I am guessing it is oil pump issue but yeah wait and see I guess.
I suggested putting it on the dyno lol, not overfilling it.
Yes however you also said sump design which is standard hahaa. No we did not put it on the Dyno. I am just playing the waiting game hahaa lol.
Yep the standard sump might not be sufficient for the Gs you are pulling is what I was getting at, hence put it on the dyno and it will very quickly tell you if it is an issue with the sump, or an issue with the build.
So you never tried it on a dyno to determine if it was the oil pump or the Gs and stock sump?
No we didn't, however some what glad we didn't. Found half a washer(looked like a washer) in the sump just floating about. If I would of upped it more and more I could have done more damage.
The crank so far looks good so there is no need to replace that yet.
I have gone by what Dan has said and he are still trying to diagnose the issue.
Pretty much what my number 6 looked like when it let go....
it had standard pistons running 285rwkw.
what generally causes the piston to break away like that... is it just cause they're weak? or is there other contributing factors?
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
