  • Replies 187
I like the last pic as well jay.. Love your perspective of the pics you capture.
ISO6400, No noise reduction.
It looks like an image of a scale model or diorama. Stood out to me instantly. Was that the intention? Long time lurker.
Sounds like you are thinking of "tilt shift photography"
*does a quick google*
http://www.smashingmagazine.com/2008/11/16/beautiful-examples-of-tilt-shift-photography/
That was the first link on Google - Haven't had a look at the photos yet but should have some good examples.
Thanks for the kind words Richie. Hopefully get a blog post up soon with all the photos from the wedding.
Nick - The photo was taken from a tilt-shift lens (45mm canon tilt shift). Purpose of the photo - none really hahah. Well just testing out the tiltshift lens as I have never used it before.
i like the shot of the pelican in flight.
just dont show any professional bird shooters, they will have a cry that its a 'butt' shot :P
(i learnt that the hard way, haha)
your beaches look a lot more interesting then our beaches. love the old jetty!
Edited by Jay019
butt shot hahaha.. Where was it taken matt? Nice set of pics.
nah didnt borrow his.. my 2nd shooter accidentally left it in my car after a shoot. So decided to take as many pics with it as possible before I gave it back to him.
Found my old 2gb memory cards.. Forgot I still had pics on there.
u sneaky f**k! i don't even remember you taking that!
Matt - how can you not remember him taking that pic. Your smiling at the camera!!!!
bad memory i guess. probably because i'm retarded.
LOL, you're a ruh-tard, Matt! :P I'm pretty sure I showed you that photo straight after I took it, too. Was just after I'd bought the G12.
I'm really happy with that purchase, BTW - it's proving to be an awesome little camera! I love having a smaller camera with most of the functions of a DSLR, so I can still play with/learn how settings work without having to carry the 60D and lenses around constantly.
Lol i was about to say no beaches in Penrith :P
Jay - Love that shot. Where is more buildings in adelaide? I think you've explored them all!
Sidd - Killing it as usal.
Nick - FCUKING LOL. Matt should use that for his Pedo pete profile. Fcuking creep.
Wilorichie - Nice shots!
Oh and a shot from me. Re-edited from ADGP.
I lost my bike messenger job so dont head into the city at all any more. It's over an hour away (3 if i ride, lol)
but... applied for a commercial cleaning position with a company that specializes in working at heights.
if all goes well i'll have access to some crazy views in future and if things go to plan i'll be able to look into specializing in photography at heights.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
