  • Replies 187
I like the last pic as well jay.. Love your perspective of the pics you capture.
ISO6400, No noise reduction.
It looks like an image of a scale model or diorama. Stood out to me instantly. Was that the intention? Long time lurker.
Sounds like you are thinking of "tilt shift photography"
*does a quick google*
http://www.smashingmagazine.com/2008/11/16/beautiful-examples-of-tilt-shift-photography/
That was the first link on Google - Haven't had a look at the photos yet but should have some good examples.
Thanks for the kind words Richie. Hopefully get a blog post up soon with all the photos from the wedding.
Nick - The photo was taken from a tilt-shift lens (45mm canon tilt shift). Purpose of the photo - none really hahah. Well just testing out the tiltshift lens as I have never used it before.
i like the shot of the pelican in flight.
just dont show any professional bird shooters, they will have a cry that its a 'butt' shot :P
(i learnt that the hard way, haha)
your beaches look a lot more interesting then our beaches. love the old jetty!
Edited by Jay019
butt shot hahaha.. Where was it taken matt? Nice set of pics.
nah didnt borrow his.. my 2nd shooter accidentally left it in my car after a shoot. So decided to take as many pics with it as possible before I gave it back to him.
Found my old 2gb memory cards.. Forgot I still had pics on there.
u sneaky f**k! i don't even remember you taking that!
Matt - how can you not remember him taking that pic. Your smiling at the camera!!!!
bad memory i guess. probably because i'm retarded.
LOL, you're a ruh-tard, Matt! :P I'm pretty sure I showed you that photo straight after I took it, too. Was just after I'd bought the G12.
I'm really happy with that purchase, BTW - it's proving to be an awesome little camera! I love having a smaller camera with most of the functions of a DSLR, so I can still play with/learn how settings work without having to carry the 60D and lenses around constantly.
Lol i was about to say no beaches in Penrith :P
Jay - Love that shot. Where is more buildings in adelaide? I think you've explored them all!
Sidd - Killing it as usal.
Nick - FCUKING LOL. Matt should use that for his Pedo pete profile. Fcuking creep.
Wilorichie - Nice shots!
Oh and a shot from me. Re-edited from ADGP.
I lost my bike messenger job so dont head into the city at all any more. It's over an hour away (3 if i ride, lol)
but... applied for a commercial cleaning position with a company that specializes in working at heights.
if all goes well i'll have access to some crazy views in future and if things go to plan i'll be able to look into specializing in photography at heights.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
