  • Replies 187
I like the last pic as well jay.. Love your perspective of the pics you capture.
ISO6400, No noise reduction.
It looks like an image of a scale model or diorama. Stood out to me instantly. Was that the intention? Long time lurker.
Sounds like you are thinking of "tilt shift photography"
*does a quick google*
http://www.smashingmagazine.com/2008/11/16/beautiful-examples-of-tilt-shift-photography/
That was the first link on Google - Haven't had a look at the photos yet but should have some good examples.
Thanks for the kind words Richie. Hopefully get a blog post up soon with all the photos from the wedding.
Nick - The photo was taken from a tilt-shift lens (45mm canon tilt shift). Purpose of the photo - none really hahah. Well just testing out the tiltshift lens as I have never used it before.
i like the shot of the pelican in flight.
just dont show any professional bird shooters, they will have a cry that its a 'butt' shot :P
(i learnt that the hard way, haha)
your beaches look a lot more interesting then our beaches. love the old jetty!
Edited by Jay019
butt shot hahaha.. Where was it taken matt? Nice set of pics.
nah didnt borrow his.. my 2nd shooter accidentally left it in my car after a shoot. So decided to take as many pics with it as possible before I gave it back to him.
Found my old 2gb memory cards.. Forgot I still had pics on there.
u sneaky f**k! i don't even remember you taking that!
Matt - how can you not remember him taking that pic. Your smiling at the camera!!!!
bad memory i guess. probably because i'm retarded.
LOL, you're a ruh-tard, Matt! :P I'm pretty sure I showed you that photo straight after I took it, too. Was just after I'd bought the G12.
I'm really happy with that purchase, BTW - it's proving to be an awesome little camera! I love having a smaller camera with most of the functions of a DSLR, so I can still play with/learn how settings work without having to carry the 60D and lenses around constantly.
Lol i was about to say no beaches in Penrith :P
Jay - Love that shot. Where is more buildings in adelaide? I think you've explored them all!
Sidd - Killing it as usal.
Nick - FCUKING LOL. Matt should use that for his Pedo pete profile. Fcuking creep.
Wilorichie - Nice shots!
Oh and a shot from me. Re-edited from ADGP.
I lost my bike messenger job so dont head into the city at all any more. It's over an hour away (3 if i ride, lol)
but... applied for a commercial cleaning position with a company that specializes in working at heights.
if all goes well i'll have access to some crazy views in future and if things go to plan i'll be able to look into specializing in photography at heights.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
