give me some feed back on this
37 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
it looks good mate :)
ive been thinking of getting a bonnet like that for my 34 with a new front bumper ... mine are both all stone chipped and kinda need a new front bumper anyway its sagging something special
i like the one without the line in the middle though if you get what i mean..
more of the East Bear one
Yeh does look good mate, well done with the mods :)
One thing to note with vented bonnets, there is a lot of science to it. What can happen with cheap bonnets or ones that aren't properly engineered is they create a low pressure zone across the top of the engine bay, which means the air will be sucked up over the intercooler and radiator instead of through it, causing cooling issues.
Also another thing, you won't get away with the "it's stock officer" line. The bonnet is a structural part of the car, modifying it as you have done modifies the structural integrity of the whole car. Meaning it is definitely sticker worthy.
Just a heads up.
Just a heads up.
holy sh** i didnt know that
  • 1 month later...
Correct!
This is why the Nismo R-Tune bonnet has a Z-Tune tube which links the bonnet with the airbox.
I didn't know this, mmmmmmm
Would I be correct in assuming that haveing a full width radiator air guide in place would offset the negative air charge?
As in forcing the air down through the IC and rad the the bonnet will "vent" the heat as one would assume it's designed for??
In God_speed's Nur Dave, he has
* R Tune bonnet (genuine) but with Z-tune tube out.
* ARC airbox (which won't accept the Z-tune tube)
* Full length air guide
> temperatures at speed are at least 4 degrees less than usual despite the ARC box being notorious for trapping heat
Wow... If that's a stock bonnet underneath and you just fibreglassed it over the top, that looks pretty impressive.
Yes my friend it is the stock one . LONG time to do it right tho
Edited by joker's r34
Just a heads up.
Looks cool, a little too "Big" for me, but still cool. Also, This ^. Definitely yellow worthy.
Does the opening make rain drain into the engine bay?
Nice work!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
