Hey guys
got the GTR goin into the exhuast within the next couple of days and trying to get a figure on how much i should be paying...
the set up is a single high mount borg warner on a twinscroll manifold
Basically the work i need done is a
4 inch v-band dump pipe to the cat
plumb the two wastegates into the exhuast
setting up the plumbing from compressor side of the turbo to the intercooler
im guessin stainless will be the way to go?
any input is welcome
cheers
https://www.sau.com.au/forums/topic/378963-how-much-should-i-be-paying/
  • Replies 57
Decent grade stainless with mandrel bends - I reckon some where around a gorilla. Actually you may get a bit of change from $1000.
$400 for the dump, $300 for the wastegates, $150 for intercooler piping.
That's my guesstimate.
Is that the going rate for a gorilla these days? $1000 is quite affordable, I could really use a gorilla around the house :P
I'd pay 400-600 for the dump including WG plumbing, add another 200 if the WGs need to be plumbed up to the manifold.
Probably another 100 ontop for the hotside pipe. Would pay up to but not over a grand for that job.
lol god I didnt think a 5 year age gap would do so much.......
cool, i was hoping it would be around the 1000 figure, hopefully less
obviously need the oxy sensor adaptors for the dump as well...
what do u guys reckon about keeping the dump pipe mild steel and heat wraping it?
plumbing 2 gates in is going to be a head f**k for the guy doing it. I'd say $1000 would be a minimum for this job. Don't forget you will need flexible bellows for the gate pipes as you won't line 2 up simultaneously once it's made. It takes just as long (sometimes longer) to do the wastegate returns - just because they are smaller, doesn't make them any easier. I reckon whoever does it would be looking at a day to do it which is going to work out to be $500-800 just in labour.
If the cat isn't already 4 inch it will also be hard to adapt it with a flange as 4inch only comes in 3 bolt triangle flanges or vband. Vband won't go easily onto a 3.5 inch cat and neither will a 3 bolt triangle flange. It will need to be stepped down before the cat and that reduces the amoutn of room you have to run the gate returns
Not an exciting job
yea definatly no denying its goin to be a major pain in the ass and labour will be the most expensive part...suppose i can expect a high end figure of 1500?
As long as they do a good job i dont mind payin a few hundred bucks extra.
do we think the dump should be stainless still?
The material wont change the cost much, I would go stainless, especially if you plan to go e85.
I think $1500 would be the starting price for a good job, there is an easy 2 days doing it all properly, grinding the inside smooth takes time but nets the extra gains. Dont skimp as crunching the fabricator and making him cut corners will cost you power.
Its not just an exhaust shop you're going to is it? A good performance workshop/fabricator is required imo.
No plans for E85 as of yet but definatly an option in the future
Your right might as well go the stainless, looks better too
The car is gettin done at Unigroup so ive organised through Yavuz to get the exhaust done, not sure who he uses but im sure they would have to be of a decent quality
Stainless costs double that of mild steel in the same tube size unless you buy it wholesale in which case it's about 75% dearer
So around $200 in tubing instead of $150 right? Labour is where the cost is.
Feel the tension :3some:
As for WG returns, lately I have been considering the stainless flexible exhaust pipe like what you see on trucks... Theres this very flexible version that sort of slots together rather than the ribbed version.
http://i00.i.aliimg.com/photo/v0/448053166/HOWO_truck_Exhaust_Flexible_pipe.jpg
That's what is inside the stainless woven flex couplings you normally see, I don't know why its not used on its own on cars, can you get it in smaller sizes?
I dont think it can be welded either as its too thin, it needs to be clamped. I agree, it would be great for wastegate piping.
well ive done a few. to do a nice dump pipe easy 4 hours.
plumbing the wastegates in will take longer. massive pain in the ass.
try and build the system using "marman" style v bands. heaps easier to work with and can take alot more tollerance for miss alignment.
the dump and screamer pipes are easy. its just getting the things plumbed into the dump pipe wich is a pain. especialy if you have little v-band wastegates. absolute cok to get on and off with the hinge type clamps.
i know first hand as i just did a 6boost with twin mvs-44 tials. borg warner 9179. on my girlfriends car rb25 r33.. just no room to move. depending where the gates are mounted will dictate how much swaring is involved.
You didnt do very well in maths at school right? Double? Lol
For example a 90 3" mandrel in ss is 3 times the price of ms.
Please post pics of the completed job so we can all drool.
well i was thinkin about leaving the gates to vent to atmosphere as it would be cheaper but i dont think thats too good of an idea for legality reasons
all i know is im glad im not doin it!!!
Will definatly post some pics when she's all done
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
