another thing I've noticed running e85 for dd all last week was how much smoother the car feels on rev up, even gear changes feel smoother
also significantly less carbon output in my exhaust tips
I was heading out at night doing quite a few tests and logs so I can't comment on typical dd fuel consumption yet
  • 4 weeks later...
ive been running E85 for a good month+ now. Im getting around 290-320 kms to a full tank inner city driving. Thats around 50km less than i was getting with 98ron. However, the smoother running, lack of carbon build up and midrange pull far outweighs the extra mileage
added some HKS SSQV 4 bovs using the HKS R34 flanges so i could mount to my oem intercooler piping
may just be a placebo but im pretty sure the responsiveness getting on/off throttle quickly at mid boost is better and a touch smoother
recirc'd they sound great (together with the TS intake and larger TS turbo inlet pipes), not ott loud, just enough to know they're there - they fluter at low boost and dump at high boost
also ordered one of these + a gm flex fuel sensor to monitor my ethanol content - and have 2x 20L drums of E100 (from racefuels) just in case the local caltex brew dips in the low 70s
Edited by domino_z
  • 4 weeks later...
Car looks stunning! Love the boot. What LSP you got on there?
Caltex is pretty much bang on E70 last few months. Only saw a bit of a dip in the middle of winter (mid 60's) prob for a little cold start help, but since then, E70.
Can the Cobb take the digital signal from the Gm sensor to alter the tune on the fly? Not sure if you know, but Trent @ Chequered set my car up with the GM sensor and a Link G4 to be completely flex-fuel capable, ie, tune will alter real time depending on the content/mixture of 98/E85. Safer and optimum performance.
Thanks for the feedback guys
Gohan no the Cobb can't adapt on the fly just yet
But I can monitor the ethanol percentage with my Zeitronix + gm fuel sensor... and I'm already hard wired for when/if Cobb release flex mapping
I do have those drums of e100 just in case I get a bad batch of e85
I've been running the caltex e85 with no issues at all, a testament to the safety margin Martin built into my map
The latest map Martin sent me feels like the boost comes on harder at lower revs, and Im getting all 4 wheels spinning through the midrange in 3rd now lol
The easy datalogging with the Cobb has proved invaluable in continually tweaking my tune. I email the file to Martin and he emails me back a revised map. 5 mins later it's uploaded on the ecu
Re LSP, its opti-coat + prima amigo + naviwax dark - I'm a hobbiest detailer and among the 30 odd waxes I have (collect) naviwax is my numero uno pick at any price point
Edited by domino_z
  • 1 month later...
Hey man, looks killa. I heard about this opti-coat stuff and seen some vids on YouTube. Where do you get it from, along with the naviwax?
the opticoat I had applied by a pro, immaculate reflections. You can buy it from zas locally, but it is quite finicky to diy
if you want to diy a coating, I'd rec you go with cquartz
you can buy naviwax off eBay uk now
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
