another thing I've noticed running e85 for dd all last week was how much smoother the car feels on rev up, even gear changes feel smoother
also significantly less carbon output in my exhaust tips
I was heading out at night doing quite a few tests and logs so I can't comment on typical dd fuel consumption yet
  • 4 weeks later...
ive been running E85 for a good month+ now. Im getting around 290-320 kms to a full tank inner city driving. Thats around 50km less than i was getting with 98ron. However, the smoother running, lack of carbon build up and midrange pull far outweighs the extra mileage
added some HKS SSQV 4 bovs using the HKS R34 flanges so i could mount to my oem intercooler piping
may just be a placebo but im pretty sure the responsiveness getting on/off throttle quickly at mid boost is better and a touch smoother
recirc'd they sound great (together with the TS intake and larger TS turbo inlet pipes), not ott loud, just enough to know they're there - they fluter at low boost and dump at high boost
also ordered one of these + a gm flex fuel sensor to monitor my ethanol content - and have 2x 20L drums of E100 (from racefuels) just in case the local caltex brew dips in the low 70s
Edited by domino_z
  • 4 weeks later...
Car looks stunning! Love the boot. What LSP you got on there?
Caltex is pretty much bang on E70 last few months. Only saw a bit of a dip in the middle of winter (mid 60's) prob for a little cold start help, but since then, E70.
Can the Cobb take the digital signal from the Gm sensor to alter the tune on the fly? Not sure if you know, but Trent @ Chequered set my car up with the GM sensor and a Link G4 to be completely flex-fuel capable, ie, tune will alter real time depending on the content/mixture of 98/E85. Safer and optimum performance.
Thanks for the feedback guys
Gohan no the Cobb can't adapt on the fly just yet
But I can monitor the ethanol percentage with my Zeitronix + gm fuel sensor... and I'm already hard wired for when/if Cobb release flex mapping
I do have those drums of e100 just in case I get a bad batch of e85
I've been running the caltex e85 with no issues at all, a testament to the safety margin Martin built into my map
The latest map Martin sent me feels like the boost comes on harder at lower revs, and Im getting all 4 wheels spinning through the midrange in 3rd now lol
The easy datalogging with the Cobb has proved invaluable in continually tweaking my tune. I email the file to Martin and he emails me back a revised map. 5 mins later it's uploaded on the ecu
Re LSP, its opti-coat + prima amigo + naviwax dark - I'm a hobbiest detailer and among the 30 odd waxes I have (collect) naviwax is my numero uno pick at any price point
Edited by domino_z
  • 1 month later...
Hey man, looks killa. I heard about this opti-coat stuff and seen some vids on YouTube. Where do you get it from, along with the naviwax?
the opticoat I had applied by a pro, immaculate reflections. You can buy it from zas locally, but it is quite finicky to diy
if you want to diy a coating, I'd rec you go with cquartz
you can buy naviwax off eBay uk now
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
