Hi guys i have just bought an r33 gts-t. its got a pod exhaust and bov aprt rom that its stock as a rock how much boost can i run with a stock turbo??
also i read you dont have to piggy back the ECU if you change the spark plug gap from 1.1mm to 0.8 has any one tried this out?
any advice would be good i want to get it quicker with out spending a mint.
cheers
https://www.sau.com.au/forums/topic/379078-where-to-go-from-stock/
The stock turbo is generally a risk to say the least, a good flogging at high boost could blow it and it might take the motor with it. Stick to 9 or 10psi tops.
As for working it without spending a mint, you will need to spend about 3 grand to get a highflow, front mount and a remap.
Goodluck.
cheers
I think you mean how much boost can the stock turbo run before blowing up. Mine has seen 20 psi a few times, 18 psi a few times, 16 psi quite a few times, 14 psi for ten months. It started leaking oil after ten months. Others haven't had my luck and their turbo has died rather quickly on far less boost.
As far as gapping the plugs go I'd say that almost everyone on this site has done it. Like GTScotT said you can get your turbo high flowed for around a grand, you can get a front mount from ebay with a pipe kit for $500 then put it in yourself, buy a second hand power fc and hand controller for a grand and get it tuned for around $500. On 12 psi this setup will net you around 190 rwkw. This will pretty much max out your injectors and your afm. So there is your $3000.
Then you spend another $500 on some refurbished injectors, $300 on a new z32 afm and a couple of hundred on a fuel pump and you'll be looking at closer to 250rwkw.
Or if you are like some others here you go out and spend $4.5k on a turbo setup that will rip you a new one.
You did say you wanted to keep it cheap tho. Run 9 or 10 psi with gapped plugs and it will go better.
yeah changing heaps of stuff down the track is good but for now ill just run 10 psi and gap the plugs and see how it goes im thinking of investing in a r34gtt intercooler apparently they bolt in where the stock one is and are good for 200rwkw should go a bit better with that stuff with out throwing hell cash at it for now
Or you could be like me and sell a car wanting a lot of money spent for a car with the money spent but job done shit lol.
Somehow I wish I had another stock as a rock car to only do what mods I wanted as well as I can actually do them.
Careful not to buy another persons problem!
sell it and buy one with the work already done, cheapest way to make power.
Indeed this. I got my r33 GTSt cheapish. $6500. Already had a hd clutch and catback. Rest was stock. Now its worth $14k to me and that's not including labour of which I have done all of it. I would have bought something already done up. Not that I regret doing up my car (I kept all the stock parts) but I could have bought a forged GTSt already done up.
My advice is this... If you want a fast, reliable, good handling skyline then sell your stock one and use the cash toward getting one already done up. Do the boos mod but don't waste any money on it. You will save easily $5k in the long run. In my case that is less than a year.
Personally, because I've been there, I would run 8psi through it while you still have a stock ECU. Mine would not run properly at all on 10psi. Easiest thing to do would be the high boost mid with the stock solenoid. Just have to cut and earth one wire and you get 7psi all the time. When you get an aftermarket ECU then go for 10-12psi
Read the tutorial on here for it. If you cut the wrong wire you'll have 5psi all the time instead
Now that would just be funny. That tutorial is easy to read and anyone should be able to do this mod. It was the first thing I did when I bought mine.
If your looking for cheap improvements buy yourself a decent bleed valve and wind in 10-12psi, gap plugs to 0.8mm, buy a second hand SAFC for $200, spend $200 getting it tuned and you'll get around 190rwkw with heaps more midrange. Not as much flexibility as a full ECU but much less cost and unless you are going to the next stage of mods you won't need it. You'll start to see the standard SMIC getting heat soaked so factor in a bigger, higher flowing FMIC. Be prepared to outlay for a new HD clutch and maybe a set of decent coilpacks in the near future as the standard one's are at least 15 years old.
Z
  • 1 month later...
hey guys sorry to add to this at a later date .. but ive bought a boost controller cranked it to 10psi and regapped the plugs and changed to the r34gtt smic cooler... im now tossing up between an safc computer, z32 nistuned ecu and a full blown after market power fc or microtech setup. i plan on in the future going high flowed turbo fuel pump and injectors big front mount cooler would the cheap safc computer not be able to cope with theses mods?? i just dont want to buy stuff that i am going to have to update down the track. the z32 ecus nistuned are great but its just as dear as a 2nd hand power fc it seems....
i would go nistune over power fc but it all comes down to your tuner go ask him what he would prefer and do according theres been a lot of power fc vs nistune and it seems nistune is starting to build some steam...power fc has had it's day time to come into the 21st century ang go nistune
For R32 and R34 I agree but for an R33 there a number of complications I believe with getting a nistune setup running well.
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
