I am getting tired of my R33's drony 3" system
I've done some research and after watching youtube videos to compare the noise difference the varex seems like a good option
Can anyone give me some feedback as to whether I should invest my hard earned $ in one?
Im looking at this one on ebay atm http://www.ebay.com.au/itm/130583220548?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Thanks
Edited by Richard GTST
https://www.sau.com.au/forums/topic/379129-varex-exhaust-mufflers/
I've sold a few sets in the past few years. None returns so far, the feedbacks on them are pretty good. But I haven't seen any one using them on high powered setups yet. (I don't carry them now, get them direct from xforce)
Their standard 3inch turbo back system worked pretty good with their cat knocked out. How ever they are considered loud.
The other best exhaust I've had was the HKS silient power system. It wasn't cheap, made only 4kws difference out of 314rwkws setup (310rwkws exhaust on, and 314rwkws exhaust off). They are pretty quite on the road.
thanks for the replies
I dont have any crazy power
atm ive only got the exhaust, r34 smic, and splitfires and it made 176rwkw on the dyno, which i was pretty happy with
in the future I'd only plan to do the usual stage one - get a fuel pump, pfc, fmic, ebc and aim around the 200rwkw mark
i think taking the bit out of the Varex that flips open and closed, and puting it between a screemer pipe and normal exhaust would be awesome... so u can flip from screamer to normal.... just throwing it out there... haha
I think you'd be better off with a HKS silent muffler of fujitsubu system, i have a 3 1/2 inch fujitsubu system , i decided this week to have a cannon welded on to see if it sounded better and it was terrible, sounded like a riced up honda or commodore ,
i also got pulled over by police for the first time, they saw me accelerating and quickly came after me like a had just robbed a bank. lol.. claimed that they saw smoke and suggested i was doing a burnout, this is just from hearing me take off from an intersection with zero boost upto 2500rpm..
so for me , id never have anything that is loud ever again..
Good quality legal level exhaust >> illegal $400 muffler.
For the price of the muffler again you get get a proper, top quality bolt on exhaust which sounds great, doesn't drone and is fully legal. Might sound pricey, but a single fine for the defective muffler and you'll have forked out more than the cost of a good quality exhaust anyway.
Do it once, do it properly. A Varex is a dodgy way to overcome an issue which can easily be rectified properly, in my opinion.
That said, if you are set on a venturi muffler, the Varex are the goods from what I've heard.
I had one on my old 32 came with the car was very loud and didn't give the crisp rb note I changed it for a apexi silent system and made it sound super mean I highy recommend the apexi system not cheap but. On my new 32 I run a rsr system sounds great not load very quite on the freeway and can be bought cheap on eBay or you may find one at a jap wreaker
Edited by Bsa
A friends dad had one on his supra, completely destroyed the 2jz sound and considering how much power he lost when it was closed he never closed it.
Just get a jasma approved bolt on. Most sound great and are legal. I've got a hks hi power and love the sound.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
