I got a wheel alignment after lowering my car 45 mm at front and 35 mm at the rear , at the same time i put some new Hankook Ventus Rs- 3 tyres on .
My previous tyres were shredded from the previous owners poor alignment , had major wear on the fronts inside edges and still had 4mm in the middle ?
Since this happened i told the guy who did the alignment , set it up more so my tyres last a great deal longer .
The next day in my garage i noticed it looked like way much camber on the rear , im after longevity ATM
So im asking is the alignment within limits , i want to make sure they did a good job !
If you don't have any adjustable stuff installed at the rear, there's nothing he can really do to remove the extra camber that you have - and the extra camber results from lowering the car. Get at least one set of adjustable bushes into it, if not two sets, and try again.
+1
And....the main previous issue was probably the amount of toe at the front, which they have corrected. At the rear there is about 1/4o adjustment to camber available from factory.
Am i better with camber arms or adjustable bushes , camber arms look easier to install rather than bushing kits ? which is better
I just got a price from pedders -( whiteline supplier) in S.A , a set of 1 degree adjustment bushes $470
and 2 degree bushes $740 which is ridiculous . Some more advice would help , thanks
The answer is to stay the hell away from Pedders at all costs.
Price up some Whiteline/Superpro bushes from various vendors. Decide if you can fit them yourself (it's not too hard), or if you would be better off getting a workshop you trust to source and fit them. It still adds up to more dollars than it seems it's worth, but in the long run you will get better tyre life, which can pay for itself pretty quickly.
+1
Got Nolathane rear-upper control arm bushes with +-1.5 degrees camber adjustment, great price and still going strong, made a world of difference to handling after lowering and has done heaps for tyre wear.....
+1
Was that with one kit or two , how much for product and install ?Thanks
They came as a pair, with 4 bushes, two offset inners (the adjustable bit) and all the necessary bolts and nuts, and fit in the upper rear-most control arm, in the hub end... Cost me $90 so expect ~$120-$140? I fitted them myself, and it sucked as the stock steel outer was seized to the hub, 3 hours total of cutting out the rubber bit, then the steel all while trying not to damage the hub.
Kit here:
http://www.nolathane...rt_number=46230
Also has a picture showing where the bush goes and what it corrects.....
Edit: My big nasty book of receipts says that I installed the kit in september last year, I average about 20,000 km per year, if that's any help as to expected life? They haven't worn out or lost adjustment yet....
Edited by blk94r33
Kit here:
A big thanks mate !
  • 2 months later...
Kit here:
Im still having some issues :
I finally got around to installing some nolathane adjustment bushes front and back also
replaced the old well camber worn tyres with some new Ventus Hancook RS-3 tyres .
I then took my car in for a wheel allignment , all good so far , until i drove it and realised the car wants to pull left and right over bumps and undulations from heavy traffic !
I took it back to the allignment guy , he blamed the tyres , i dont really believe the douchebag pinch.gif
Can anyone read this , do i need more toe or anything to stop the tramming effect ???????
Camber left rear -1 12'
right rear -1 53'
toe left +1,1mm
right +1,2mm
Caster left + 3 08'
right + 3 33'
Camber front left -0 49'
front right -1 16'
toe left +1, 4mm
right +1, 5mm
FACTORY SETTINGS;
TCamber rear - 1 15'
Toe IN rear 4-0
Caster 3 55'
Camber front -0 50'
Toe IN front 2-0
Edited by NISSAN GTR
Tyres will definitely contribute to tramlining. Look for reviews of that tyre that mention it (in case lots of other people have the problem). Trouble is, it can be specific to car and/or setup too. Same tyre on different cars and you get different opinions about how bad they tramline. Anyway, looking at your alignment report, the only problem is that it could use a bit more camber on the front left, to match the front right. Having them different like that might make it grab hold of camber differences in the road (like grooves from heavy traffic, like you complain of) and drag the car around.
But that's usually how alignment place do it, same experience with a bridgestone tyre center here as well, ask them to do -2 camber all round, car came back with more camber on passenger and less on driver side, they usually do it to offset the slight camber on the road
Oh, yeah, I agree and got involved in an argument on here about it only a couple of weeks ago......just pointing out that it's about the only thing visible in the report that looks like it would cause tramlining. (and in this case his camber difference is the other way around, but we'll ignore that for the moment).
The annoying thing was the car use to steer amazingly with race car like cornering , but now the tyre wear/camber/toe is sorted out its pretty ordinary to drive now wacko.gif
Means your old alignment is good for the track but not good for tyre wear when just driving normally. Theres always compromises when setting your car up to perform better for the track and tyre longevity for daily driving. like for example: you set your car up to have more negative camber so you get better turn in and maximum contact patch when cornering, making full use of your tyre's grip at the track but the trade off is when driving normally or in a straight line, the excessive negative camber means only the inside half of the tyre is contacting the road which will chew out your tyres. Race alignment and daily driving/factory alignments dont mix as each have their compromises.
Looking at your wheel alignment report, theres still way too much negative camber at the right rear which means your left rear tyre has more contact patch(possible cause as to why it pulls left since more of the left tyre is contacting the road) on the road than the right and becomes worse when you sit in the car as the driver's weight will make the right side sit slightly lower, increasing negative camber at that corner and make its contact patch worse. how much has your car been lowered? excessive lowering means the adjustable bush has reached it limit (this is why i went adjustable arms as they have more adjustment range even at the expense of NVH which i can live with if it means longer tyre life or better alignment control) and cause the aligner to not able to add more positive camber but id be asking the aligner whether this is why he couldnt adjust your right camber more though that said, he should have mentioned this to you when you pick your car up.
Note if your tyres are still the same ones that are on the car before the alignment is done, dont think that the problem will go away after the alignment as there is 'tyre memory' where the tyre is worn according to the old alignment and can contribute to the cars sporadic behaviour that cant be fixed with a wheel alignment unless the tyres are changed and another wheel alignment carried out to suit the new tyre. but seeing as you've replaced your tyres and had a wheel alignment carried out together, i guess your problem is now your current alignment which we can clearly see is a possible cause to your car's behaviour. note i said possible as there can be many other factors that can cause any vehicle to pull. hope this makes sense :)
Edited by R33_NICK
thumbsup.gifThanks for your response , yes the car has been lowered 40mm front 25 rear , also i installed nolathane camber adjustment bushes to counter the camber wear on tyres .
i dont think the rear camber being slightly out on one side will cause the steering wheel to pull side to side- front , my old GTR did the same (tramlining) only because the tyres were massive inside tyre wear .
The current tyres are brand spankers , installed just before allignment and bushes .
Do you think changing front tyres around" temporarily" so they are not directional , will let me know if its tyres causing the problem - RS3 Ventus , also changing front bearings will make a difference ?cheers.gif
No worries :) . I do wheel alignments almost evryday at work.
Yes, you can try swapping them left to right to see if it pulls to the opposite direction. it'd be better if they arent directional but it should be ok if its just temporary for checking. if it does pull to the opposite direction, then its the tyres that are at fault but if it still pulls to the same direction, then its the alignment. if your wheel bearings have play in them they may contribute to the car's behaviour but not so much to actually make the car's behaviour on the road that badly. if you have free-play in your wheel bearings, it is advisable to change them first before an alignment is carried out but i dont think that is your problem at the moment especially if theres no freeplay.
sometimes when the camber is out on one side at the rear, it can cause the car to pull because the tyre that has the most contact patch will mean that they have more grip on the road and being equipped with LSD where you get both wheels spinning at the same rate, the tyre with the most grip will cause the vehicle to pull to that direction where it has the most grip almost similar to torque steer, which affects its thrust angle that also affects the front alignment or steering direction causing crabbing or tram-lining(which is why with LSD equipped vehicles or AWD cars especially, its advisable to have the same type of tyre, thread pattern or wear on both sides as any difference can have negative impact on its behaviour on the road). I had a car that was pulling quite badly to the right and when i checked his wheel alignment, there was too much negative camber on this example the left side and his car was pulling badly to the right because the right side camber is more neutral hence that tyre has more contact patch/grip. luckily his adjustments havent maxed out so i was able to adjust his camber to be equal all round and the car drove fine after that. also keep in mind if you drive the car on that alignment for awhile your tyres are going to wear according to that set up. but in your case, id start by swapping the front tyres left to right to see if it pulls to the opposite direction or all of a sudden it drives straight. if it doesnt change then we'll need to pay close attention to the wheel alignment as mentioned above. AWD cars need more attention with their wheel alignments.
i'd still ask the aligner whether the right hand rear camber adjustment has maxed out seeing as he's just left the camber alone like that because if its my car, i cant accept it unless the adjustment bush has actually maxed out which means you cant do anything about it unless you have adjustable arms. but if theres still room to move, theres no excuse as to why he couldnt neutralise it more. i wont call this current setting compensation alignment as your current camber settings are opposite of what it should be for compensation of road camber+driver's weight.
Edited by R33_NICK
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
