  • Replies 162
Bathurst is too clinical now...
Needs more Brock/Moffat/Johnson/Geoghegan/Jane flipping kunts the bird as they rocket past an old Volvo/Corrolla/Hillman Imp across the top in an Underbraked cross ply tyred Mustang/Torana/Falcon/Camaro
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
